Old 27-07-09, 08:47 PM   #1
sv650nutter149
Default hid problem
hi all i have twin hids on my sv.....the ones with hi and low beam.. what my problem is that the left had one seems to get stuck on high beam sometimes due to the flicky bit getting stuck any ideas what could cause this? or is it just dirty and need abit of tlc?
ta
ian
Old 28-07-09, 07:08 AM   #2
Spanner Man
Default Re: hid problem
Good morning.
'Flicky bit'? Are we to assume that you mean the dip switch? If so, give it a little squirt of lube such as GT85.
However as it's only one headlight that's sticking on main beam, it's more likely that it's the change over relay that's at fault. Some of the HID kits available are of pretty poor quality.
Cheers.
Spanner Man
Old 28-07-09, 07:24 AM   #3
the_lone_wolf
Captain Awesome
the_lone_wolf's Avatar
Sounds like he's on about the moveable shield
If it's not working properly then I'd say send it back, it's part of the high voltage end of the system so I wouldn't want to be taking it apart...
(•_•)
( •_•)>⌐■-■
(⌐■_■)
Deal with it...
Old 28-07-09, 07:36 PM   #4
sv650nutter149
yes this is the sheild
car tax and mot problem kwak zzr Idle Banter 8 23-02-08 11:20 PM
sky tv problem? hovis Idle Banter 46 09-01-07 06:36 PM
Battery problem / Alternator problem? localhost SV Talk, Tuning & Tweaking 4 07-07-06 09:32 AM
PC problem - can anyone help please? El Saxo Idle Banter 13 07-02-06 02:55 AM
