Old 05-08-09, 04:50 PM   #1
Wideboy
Evel Knievel
Wideboy's Avatar
Default grinding noise
my car has developed and grinding noise from the cambelt area and sounds as though a bearing is shot, question is i cant work out on what, water pump or pullys?
I've tried the old trick of poring water over the pulleys to see if they would quieten down but no luck
anyone else got any sugestions?
05 DRZ400E
RIP hovis
Old 06-08-09, 12:17 PM   #2
Wideboy
Evel Knievel
Wideboy's Avatar
Default Re: grinding noise
anyone?
05 DRZ400E
RIP hovis
Old 06-08-09, 12:21 PM   #3
Rai86
errrrrrrrrrrrrrrrrr......sorry
Old 06-08-09, 12:30 PM   #4
Wideboy
Evel Knievel
Wideboy's Avatar
well i got some driving to do tomorrow so i don't really want to strip it down anymore than i already have
05 DRZ400E
RIP hovis
Old 06-08-09, 12:34 PM   #5
Scoobs
What do the belts drive? Water pump, alternator? Are they too tight?
Old 06-08-09, 12:35 PM   #6
ophic
ophic's Avatar
I had this problem on a Vauxhall Agila and it was the water pump. Sorry if this is no help whatsoever...
Silver SV650SK3, Fuel exhaust
Old 06-08-09, 12:39 PM   #7
Wideboy
Evel Knievel
Wideboy's Avatar
the whole shebang i cant pin point the noise exactly as its so loud, its been like it for a while but got louder all of a sudden last week end but still running sweet as a nut so im fairly sure its a shot bearing
i will be replacing the cambelt when replacing what ever it is that needs replacing, i fairly sure its the water pump as its common but would like to be sure than just guess
the water trick is the only one i know
05 DRZ400E
RIP hovis
Old 06-08-09, 12:39 PM   #8
Wideboy
Evel Knievel
Wideboy's Avatar
just backing up my thoughts lol
might just say nuts to it as i can get parts at trade just times are tight
05 DRZ400E
RIP hovis
Old 06-08-09, 12:42 PM   #9
Red Herring
Red Herring's Avatar
Apparently if you hold a metal rod of some description against the suspect bit of engine, and the other end to your ear, you can work out where the noise is coming from. Just make sure you don't hold it near anything that might fire it through your skull!
Old 06-08-09, 12:50 PM   #10
Scoobs
gears grinding KillaSV SV Talk, Tuning & Tweaking 1 16-03-08 07:39 PM
grinding noise from back wheel 650sx Pennine Massive 4 03-05-07 01:01 PM
Baph goes peg grinding... Baph Bikes - Talk & Issues 24 12-04-07 05:46 PM
Grinding 1st!! Spider SV Talk, Tuning & Tweaking 9 02-01-07 02:50 PM
Screeching noise? what noise does your SV make? branny SV Talk, Tuning & Tweaking 5 30-06-06 12:09 PM
