Old 13-08-09, 12:08 PM   #1
ocr_sv
Default rear brake resevoir location question
On the curvy the rear brake resevoir is located in the tail, i'll be fitting a new back end on the bike soon, and i wanted to move it,
i notice on some bikes they have the resevoir just above the lever, (even the newer sv has it not much higher than the cylinder)
however i tried locating it there, and it didn't work, i was quite confused coz i was unsure whether it was the new braded line, or the vfr750 caliper that was causing the problems, but i fitted it back to the longer tube and held it where is is normally located in the tail, and it worked fine,
does it rely on gravity to an extent, and if it does how come some other bikes can run the resevoir directly ontop of the cylinder
Old 13-08-09, 01:01 PM   #2
dirtydog
Knob faced knobster
dirtydog's Avatar
Default Re: rear brake resevoir location question
I'm not actually sure the answer to your question but you could fit one of these.
http://tyga-performance.com/site/pro...roducts_id=459
2011 Speed Triple 1050
Old 13-08-09, 03:19 PM   #3
petevtwin650
I had one of those fitted to my Curvy to make bleeding the rear easier. The only slight problrm I encountered was the pipe seemed to bleed fluid and regularly needed drying off with a tissue.
Old 13-08-09, 05:32 PM   #4
Yes, the fluid does rely on gravity to supply the cylinder but only to the extent that it needs to be above the master cylinder and the pipe only goes downhill. Within reason you can put it anywhere as long as it's above.
Old 13-08-09, 09:30 PM   #5
ocr_sv
tried it just above it with an inch and a half piece of pipe, and it didn't work?
looks like it might just have to go in the tail
Old 13-08-09, 09:35 PM   #6
When you say, 'it didn't work', specifically what do you mean? Were you unable to fill the system, or could you not get it to bleed?
Or... something else .
Are you sure that it was entirely level and the fluid could run downhill to the cylinder? An inch above the cylinder is plenty.
Old 13-08-09, 09:41 PM   #7
ocr_sv
it was all level, when you pumped the brake it wouldn't bleed, even took off the rear brake line and it wouldn't pump out then either
Rear shock remote resevoir leak - help! Ginjaian SV Talk, Tuning & Tweaking 4 26-03-09 06:51 PM
zx600r rear 'break' question, (rear brake). steve.s Bikes - Talk & Issues 6 19-02-09 07:50 PM
Brake Fluid Resevoir Diaphragm and level check branny SV Talk, Tuning & Tweaking 11 27-01-09 04:11 PM
Curvy Brake resevoir cap richwill68 Stuff Wanted 2 01-07-08 05:55 PM
Rear Brake Cleaning Question glade SV Talk, Tuning & Tweaking 3 11-07-07 05:53 PM
