Old 16-08-09, 07:57 PM   #1
Fidgey2005
Question Can someone help my restricted SV stop stalling please?
Hello all, this is my first post so i hope someone may be able to help me.
I have a 2004 SV650 S K3, when i bought it in March i had it restricted to 33bhp because of my licence and ive been having a problem with it conking out of me.
The bike starts up fine but when its sat idleing hot or cold, after a while it sometimes stalls. It also does this when i come to a stop at a junction/traffic lights and try and knock it back into first gear to go it stalls again with me having to rev it up to 2000 revs and drop it into first to get it going again.
Its last trick a couple of times has been when ive been going at speed 70 + mph and jump up the gears accordingly it has stalled again, ive always managed to simply start it up again when im moving along luckily but it can certainly be a bit nerve racking
Does anyone have any tips for me to try and fix this? Ive thought about altering the idleing speed perhaps? and ibve thought it could be getting too little air.
Would be grateful for any tips to fix this. Nancy
Old 16-08-09, 09:02 PM   #2
Holdup
Default Re: Can some help my restricted SV stalling please?
What does the bike idle at? recommended 1200 - 1500 rpm, when was the last time the bike got really wet? front spark plugs commonly get wet on the SV which can cause stalling, also which restriction do you have out of intrest, ECU or FI international kit?
HTH
Old 17-08-09, 05:17 PM   #3
jacksuzukisv650
it does the ecu myn restricted my sits bout 1450 revs wen cold and goes down sleightly wen warmer roughly myt be a dodgy restrictor put ful power on and try it se if does the same
Old 18-08-09, 11:49 AM   #4
vardypeeps
Sounds like a low idle speed as mentioned above.
Get back to us on that as it should fix your problem
Old 18-08-09, 09:37 PM   #5
Fidgey2005
Hi all, thankyou for your tips. Im going to alter the idle speed tomorrow and see if thats sorts it. Will let you know. Nancy
Old 18-08-09, 09:46 PM   #6
Wideboy
Evel Knievel
Wideboy's Avatar
could be your clutch not adjusted properly, would be a cause of it stalling going into 1st but then that shouldn't cause it to stall at speed, idle speed sounds the problem
05 DRZ400E
RIP hovis
Old 23-08-09, 08:36 PM   #7
Fidgey2005
Hi all, well im pleased to say raising the idle speed to 1250 seems to have solved my problem. Went for a long ride today and didnt stall once
Now just gotta fix my sticky rear brake, and indicator relay, and she will be perfect
Stalling on Reving mbuk SV Talk, Tuning & Tweaking 8 02-06-08 11:56 PM
Its Still Stalling On Me. John 675 SV Talk, Tuning & Tweaking 13 17-06-07 05:25 PM
Randomly stalling! :O Duck-man SV Talk, Tuning & Tweaking 9 17-10-06 03:40 PM
Stalling Bike doe SV Talk, Tuning & Tweaking 4 06-05-06 07:27 AM
Bike stalling TC3 SV Talk, Tuning & Tweaking 11 19-08-05 06:21 AM
