Old 26-08-09, 06:29 PM   #1
BanditPat
Default Bump starting my 250 Bandit.
So i went into the garage to get the bike out to go meet some mates about to hop press the starter and the engine doesn't turn over i thought ok the starter motor was temperamental a while back so I'll bump start it i live next to a big hill so its not really a problem down the hill got a bit of speed and when I let the clutch out it just locked the back wheel. pushed it back up the hill and into the garage, whipped the alternator cover off and tried to turn the flywheel with my hand and try to move the back wheel and see if the flywheel moved well it moved about 2 mm so the engine definatly isnt turning over. Does any one have any ideas what may be wrong? Its a 250 Bandit, little 250 Inline 4. Thanks
Old 26-08-09, 06:34 PM   #2
Spiderman
Where the hell am I?
Spiderman's Avatar
Default Re: Damn Damn Damn
Bump starting an SV takes timing and pracice mate. You gotta bump your butt down hard onto the seat at the same time as letting the clutch out to ensure the rear whell has enough traction and grip to turn the engine otherwise it just locks as you say.
Old 26-08-09, 06:35 PM   #3
It's a 250 bandit, read the post
Are they screw and locknut valves like bandit6 or shimmed ones like late oil boiler gixer?
Old 26-08-09, 06:36 PM   #4
BanditPat
Not an SV its a Bandit had to bump start it a fair bit when the starter was being Dicky and I never had a problem
Old 26-08-09, 06:38 PM   #5
BanditPat
THey are shimmed(I think) Its nearly 20 years old so i cant see it being a complicated engine.
Old 26-08-09, 06:42 PM   #6
Screw and locknut came before shims.
Original GSXR750 was screw+nut, 1100 was screw n nut up until 1990-odd. Last of the oil-boilers were shimmed. All the water boilers - shimmed. SRADs and everything since ... shims.
Will the flywheel turn with the clutch in?
If yes, gearbox problem. If no, engine problem.
Remove some parts of the starter gear, now will it turn? If yes, starter clutch or motor issue. If no, engine issue.
Basically start removing ancilliaries driven from the crank, if no joy, pull the head cover off and check for obvious mechanical carnage. Then take the head off and see if valves have met pistons.
Old 26-08-09, 06:44 PM   #7
Spiderman
Spiderman's Avatar
Tha'll teach me to skim read things. D'oh! Sorry.
Old 26-08-09, 07:01 PM   #8
BanditPat
Well took the alternator cover off again and grabbed hold of the flywheel and managed to turn itby hand about quarter of a turn after a fair bit of effort te pressed the atrter and its working again i dont know what was wrong with it took it round the block and it sems to be fine so hopefully thats the end of it thanks for the hep both fof you
Old 26-08-09, 07:02 PM   #9
Spiderman
Spiderman's Avatar
at least i helped with some comedy Glad its working now.
Bandit starting issues thedonal Bikes - Talk & Issues 21 30-04-09 11:11 AM
Bump/push starting? AndyBrad SV Talk, Tuning & Tweaking 6 18-03-09 10:25 AM
bump?? what's it mean charlie13 Idle Banter 5 26-10-07 09:22 AM
Bump pad insideyou SV Talk, Tuning & Tweaking 1 30-09-07 02:55 PM
