Old 30-08-09, 04:47 PM   #1
shakie1973
Default removing seat trim
I need to get to my datatool, as the siren has packed in and after speaking to a datatool tech guy, he said that i need to change the case, as this is where the siren is located. Not a big deal price wise, just £14.99. Thing is ive hade the seat off and its really well tucked away. Once the seat, and pillion seat are removed im then gona have to take off the surround to get at the alarm unit. I removed the pillion grab rail and took a few more bolts out, but it seemed to have a good hold still, maybe from underneath, not sure.
Does anyone know of a link showing you a step by step, or could someone talk me through it.
cheers!
Old 30-08-09, 05:03 PM   #2
Spiderman
Where the hell am I?
Spiderman's Avatar
Default Re: removing seat trim
OK, under the seats you will see screwheads with rubber mounts under [1] , you need to undo those.
Next there will be one or 2 screws holding the plastics together behind the riders seat [2]. Undo these and also remove the backing plate bit for the srew or they will fall off and you'll loose them when you try and seperate the plastics.
Near the number plate, under the seat unit, there are 2 more screws that you will need to get to and remove if you need to get the entire tail unit plastics off. Hopefully you will be able to access what you need with the tail unit in place tho by just moving the plastics out the way.
Be gentle with the plasics tho.
HTH.
Edit: image added for clarity
Old 30-08-09, 05:22 PM   #3
Mr_Chin
SV1000 portal has a step by step guide on doing this. Chin EDIT, it's in the FAQ section, post by Bjam. I can't post a link as I'm using my phone at the moment.
Old 30-08-09, 06:09 PM   #4
Spiderman
Spiderman's Avatar
Chin... cant access images without an account tho.
Old 30-08-09, 08:12 PM   #5
Mr_Chin
Shakie/Spidey, This website is an excellent resource for SV owners so I'm posting it up here for everyone to see:
www.suzukisv1000.com
Look in the FAQs, everything is there.
HTH.
Chin
Givi Maxia 52 trim panel Aidan For Sale - SV's and SV related items 0 16-12-08 01:39 PM
SV650 Road trim to race??? weecorey Mini-Twins 8 02-09-08 06:55 AM
Removing Seat Unit 02 Curvy Stewbie SV Talk, Tuning & Tweaking 4 31-08-08 10:31 PM
k2 naked -panel you take of just before removing front seat. ejohnh SV Talk, Tuning & Tweaking 1 02-12-06 09:32 AM
Removing front seat nigh on impossible (for me). DanAbnormal SV Talk, Tuning & Tweaking 18 17-03-06 08:31 PM
