Old 07-09-09, 12:20 PM   #1
krhall
Default Tyre Pressures - Road?
After a couple of trackdays recently where I have let the tyres on the CBR down from the manufacturers suggested 36 front 42 rear, to 32 front and rear.
I have not put them back up from the last one however and am wondering what the pressures really should be, especially with winter approaching fast.
Thanks,
Kev
Old 07-09-09, 12:27 PM   #2
plowsie
Default Re: Tyre Pressures - Road?
RTFM
Or check with your tyre supplier.
BTW - did Honda suggest 42 rear?
Old 07-09-09, 12:29 PM   #3
flymo
flymo's Avatar
Any reason why you wouldnt stick with manufacturers figures? Occasionally you get a different set of pressures recommended by a tyre manufacturer in which case I would follow their advice but otherwise stick with standard pressures.
Old 07-09-09, 12:32 PM   #4
Scoobs
I always found the recommended pressures best on my CBR. Dropped them by 2 - 4 psi and it just felt squirrelly. Can't get the heat in them on the road to get the pressures up. Always felt most confident at 36F - 42R
Old 07-09-09, 12:48 PM   #5
Holdup
Honda 36F 42R
Old 07-09-09, 01:18 PM   #6
krhall
Holdup what honda dealer do you work at?
Old 07-09-09, 02:49 PM   #7
sv-robo
Tend to ride with mine 2psi down on factory recomendation..34f/40r,bike just feels a bit more planted on the road but each to thier own i guess.
Old 08-09-09, 06:33 AM   #8
Geoffrey
it is the tyre manufacturers recommendations you should follow; not the bike manufacturers
Old 08-09-09, 06:39 AM   #9
rictus01
rictus01's Avatar
Depends, what tyres you have, what you like and what you're doing with the bike, change mine as and when I deem in necessary it's another of those; if you can't feel which is best stick to what is recommended.
Cheers Mark.
Old 08-09-09, 07:10 AM   #10
krhall
Bike recommended feels a bit twitchy at times, 32 & 32 feels great on track but not so great on the A2 on my commute. I have put them back this morning but might try SV-Robo's idea of just down a couple.
I am just concerned about winter commuting on the CBR again, although if I'm honest and could find a supermoto for 1k then that would be very tempting.
Road Tyre Pressures and tyre problems G Bikes - Talk & Issues 14 05-06-08 03:29 PM
Tyre Pressures plowsie SV Talk, Tuning & Tweaking 15 24-10-07 09:38 AM
Tyre Pressures fullstop102 SV Talk, Tuning & Tweaking 8 30-06-06 02:54 PM
Tyre Pressures Banus Bikes - Talk & Issues 3 16-01-06 05:24 PM
tyre pressures parky SV Talk, Tuning & Tweaking 1 04-01-70 04:56 PM
