Old 10-09-09, 12:06 PM   #1
arcdef
Default Clutch cover.
Ok so taken mine off, there was a leak and just want your opinion on whether it is distorted or not, I know it clearly has a slight curve in it but don't want to go and order the replacement at £70 to find it exactly the same!
Cheers,
Ash.
Old 10-09-09, 12:10 PM   #2
Scoobs
Default Re: Clutch cover....
In my experience, once they are warped it is only a matter of time before they start leaking again. I put a new o-ring gasket in mine and used blue hylomar gasket sealant. Also torqued to correct torque and it started leaking again a couple of weeks later.
Old 10-09-09, 12:12 PM   #3
arcdef
So i might as well bite the bullet then!
Old 10-09-09, 12:13 PM   #4
Scoobs
If it is a minor leak, I'd just put up with it. If it is pishing out then I'd change it.
Old 10-09-09, 12:15 PM   #5
Scoobs
Check the following link: http://forums.sv650.org/showthread.php?t=136890
Old 10-09-09, 12:51 PM   #6
Dangerous Dave
I personally would continue to use it, the one on my 800 is worse. Tighten the bolts to 10Nm, no more, and use silicone sealent.
Old 10-09-09, 01:29 PM   #7
arcdef
OK so I must be being a complete retard, however, I can not get the O ring to fit the cover, and the old one which I just took out wont fit either! What am I doing wrong then lol????
Old 10-09-09, 01:31 PM   #8
Scoobs
Nothing. The OEM Suzuki O ring is a ****er to fit properly in to the groove. Get some hylomar gasket sealant and put a good dollop in the groove, then "patiently" try and stick the O ring into the groove.
Old 15-12-09, 08:22 AM   #9
sundog
Hi.i had the same problem and with 2 minutes in the freezer it just tightened up enough to fit perfectly in.it didnt damage it in any way either.hope this helps in future
Old 15-12-09, 07:22 PM   #10
5hort5
I had the same problem, freezer didn't work so I cut it, super glued it back together then put some bathroom silicone sealant around (under and over), just a bit, stuck it back on and it hasn't leaked since
Does it look like this
http://forums.sv650.org/showthread.php?t=142155
5hort5 is offline   Reply With Quote
Weepy clutch cover noob-saibot SV Talk, Tuning & Tweaking 28 17-12-09 08:22 PM
Clutch Cover carsounds_dan SV Talk, Tuning & Tweaking 17 12-06-08 04:27 PM
Clutch cover. scottjames SV Talk, Tuning & Tweaking 8 16-04-08 11:30 AM
clutch cover leaking habbie SV Talk, Tuning & Tweaking 0 06-05-07 02:07 PM
cracked clutch cover alka SV Talk, Tuning & Tweaking 3 28-06-05 09:34 AM
