Old 10-09-09, 10:21 PM   #1
chakraist
Default Vibration under braking
Similar to http://forums.sv650.org/showthread.php?t=107342 this thread, on my K3 750 GSXR front ended bike (a '00 SV650s), when I brake a little I can feel something from the disc, and when I'm trailing the brake fairly hard into a right hander there is a massive, huge vibration from mainly the right hand disc. Now I've just changed discs and pads and the problem is still there- it was there before and I put it down to the disc.
Any ideas?
Thanks in advance guys
Old 11-09-09, 08:14 AM   #2
Red Herring
Red Herring's Avatar
Default Re: Vibration under braking
Have you checked the wheel run out and balance? Didn't you have a small off recently at Lydden? Is it possible the front tyre has been moved on the rim? If they're all OK I'd probably check the forks next.
Old 11-09-09, 08:23 AM   #3
flymo
flymo's Avatar
or both sets of discs could be warped, check them with a dial indicator
Old 11-09-09, 09:23 AM   #4
custard
+1 warped disc
Old 11-09-09, 09:39 AM   #5
drag
If it's warped discs you'll feel the lever pulsing under straight line hard braking ..
Old 11-09-09, 09:45 AM   #6
TSM
The Sick Man
TSM's Avatar
Ive done the same on my SV/GSXR, i warped several sets of disks, could also be wheel bearings. All depends on if you can feal the brake lever pulse or not.
Old 11-09-09, 11:15 AM   #7
Dangerous Dave
I agree in that it sounds like a warped disc, at low speed you will feel a pulsing through the lever where as at higher speeds it feels like a harsh wobble/vibration.
Old 11-09-09, 11:16 AM   #8
vardypeeps
Could be your bearings?
Old 11-09-09, 11:27 AM   #9
Dangerous Dave
You would feel that all the time, not just when braking.
As a precaution lift the bike onto a front a rear paddock stand and check for free play.
Old 11-09-09, 11:30 AM   #10
I had a knackered wheel bearing which would only cause wierdness under braking. Not what I would call "massive vibration" though.
Just how much vibration should there be? leebex SV Talk, Tuning & Tweaking 15 05-07-09 08:19 PM
Weird vibration under very heavy braking chakraist SV Talk, Tuning & Tweaking 17 14-09-08 05:20 PM
Bar Vibration SAMMY650 SV Talk, Tuning & Tweaking 5 19-06-08 06:08 AM
Vibration Giffer2 SV Talk, Tuning & Tweaking 24 17-06-07 12:09 PM
Vibration Grinch SV Talk, Tuning & Tweaking 7 12-01-07 03:17 PM
