Old 24-09-09, 08:45 PM   #1
sunshine
Default Used oil for chain lube
I have lots of used oil in the garage, my mate advises me never to use old oil on a chain. but will it do any damage if i use my old oil on the chain? Its not going to be used in a Scottoiler, if that makes any different.
Old 24-09-09, 08:47 PM   #2
hovis
Default Re: Used oil for chain lube
Old 24-09-09, 08:57 PM   #3
Dave20046
Dave20046's Avatar
I believe hovis is suggesting a search. I think old oils fine in a scottoiler. I don't have one but occasionally run my chain through old oil before using lub/wax
Hovis's sig: where do we find the ar poll & why the hell do we have to decide a year early?!
Edit : infact in reflection I guess it helps with organizing it!
Old 24-09-09, 08:59 PM   #4
jambo
jambo's Avatar
http://forums.sv650.org/showthread.php?t=138222
While the title of the thread is slightly different, it's discussed at length at the end of the thread.
Jambo
Old 24-09-09, 09:00 PM   #5
MrTom
Hitler it may be, but its very hard to search for oil related topics as 'oil' is too short a word for the search.
Old 24-09-09, 09:02 PM   #6
sunshine
I did search couldnt find anything useful, they only say about using them with a scottoiler so i thought i would ask :P
Old 24-09-09, 09:05 PM   #7
ejohnh
Some people say it's fine. Others(including me) wouldn't use it simply because it is 'dirty' oil. It's probably ok, I just wouldn't taint my gorgeous Eileen with dirty oil ;o)
Old 24-09-09, 09:14 PM   #8
google.com
used engine oil chain site:forums.sv650.org
et voila
It is dirty in as much as it is black, however suzuki helpfully provide a fine mesh, high pressure filtering system to ensure it isn't all that bad.
I think it was jambo said "10 minutes ago this oil was suitable for lubing an engine spinning at 14000 rpm, dropping it out of the engine doesn't make it useless"
Old 24-09-09, 09:31 PM   #9
ejohnh
Yep, Yorkie, we all choose our own path to heaven. After 3k miles or so the oil just ain't what it was. Maybe it's good for chain lube. Maybe I'm just a obsessive bugger about using 'used' oil on my chain and sprockets. Maybe you are right. Maybe I am wrong, Maybe. It's all a matter of personal choice and no big deal.
I'm a bit confused about the filtering system though. Doesn't that just ensure that the crap that is generated by the combustion process and engine/gearbox dynamics, stays in the sump and doesn't get circulated back through the engine etc?
Old 24-09-09, 09:36 PM   #10
No, the crap remains in the filter, it can't get back into the sump because there is a check valve and 80psi of oil pressure stopping it.
But, the nastiest stuff is acid from combustion, the oil has buffer compounds in it to neutralise these.
Probably best compromise is really cheap car oil and a loobman oiler.
How much lube? (Chain lube!) AndyL SV Talk, Tuning & Tweaking 10 10-01-09 08:04 PM
How often do you lube the chain? Binky SV Talk, Tuning & Tweaking 27 11-08-08 03:56 PM
Chain lube TC3 Bikes - Talk & Issues 7 02-09-05 02:24 PM
Chain Lube fred_dillon SV Talk, Tuning & Tweaking 12 25-05-05 08:30 PM
Chain Lube splke Ancillaries 11 28-10-04 09:22 AM
