Old 13-10-09, 05:46 PM   #1
Rob969
Default Speedo not working
Ok went out for a ride this afternoon and all was fine then i notice the speedo needle dropping down to zero for a few seconds then its ok again. This happened about half a dozen times before it eventually stopped working for good. The rest of the instruments are fine, so before I start looking into this am i right in thinking the first checks to do are the wiring connections from rotor and speedo. Is there anything else that could cause this apart from wiring or the speed rotor. I'm inclined to think its a dodgy connection as it was intermitent first.
Old 13-10-09, 06:34 PM   #2
BillyC
BillyC's Avatar
Default Re: Speedo not working
Search, and you shall find.
Old 13-10-09, 06:38 PM   #3
flymo
flymo's Avatar
Its probably a mashed speedo rotor. Remove your front wheel and catch all the little bits that fall out.
Old 13-10-09, 07:42 PM   #4
Warthog
Mashed speedo rotor I guess too. Even if they are mashed, the bits inside can still cause it to turn for a bit whilst it is getting more mashed, so it will manifest as an intermittent fault for a while. Search the forum for more threads on speedo rotor checks and swaps if you need more info.
Old 13-10-09, 11:49 PM   #5
sv_rory
I would also say its the speedo rotor, they aren't particularly stong and do break easy.
Old 14-10-09, 01:27 AM   #6
mikelcfc
will probs be speedo rotor, £20 from main dealer, seems really common,as already said front wheel off and watch the peices fall out of the speedo bit
Old 14-10-09, 01:34 PM   #7
STRAMASHER
STRAMASHER's Avatar
...and superglue them back on.
I'll be on my 3rd when I run out of glue.
Old 14-10-09, 01:59 PM   #8
monkimagic
That would be my guess, easy fix
Speedo not working. boingboingduke SV Talk, Tuning & Tweaking 6 06-07-09 06:48 PM
Speedo working, then not, then working??? krhall SV Talk, Tuning & Tweaking 25 24-04-08 11:35 AM
speedo not working ? muffin SV Talk, Tuning & Tweaking 2 16-01-08 08:26 AM
Speedo not working Elio SV Talk, Tuning & Tweaking 4 20-02-07 12:32 PM
Speedo not working :o( PoRk ChOp SV Talk, Tuning & Tweaking 7 17-05-05 05:58 PM
