Old 20-10-09, 06:57 PM   #1
sz1
Default recommend me a tre
can any one recommend me a tre seem to varey in price
cheers Craig
Old 20-10-09, 07:04 PM   #2
TazDaz
Default Re: recommend me a tre
I can't recommend anything, but I thought the general consensus on here was that the TRE and Power Commanders were pretty pointless for an SV.
Old 20-10-09, 07:04 PM   #3
Dave20046
Dave20046's Avatar
what bike?
can be done diy on an SV650. Method's slightly different from gen1 sv to gen2 sv I believe. (If it is an sv at all).
There's also a debate as to whether it works
Old 20-10-09, 07:04 PM   #4
Popular opinion on the Org is don't waste your money on one of these, you won't notice any difference in performance.
Old 20-10-09, 07:05 PM   #5
what bike?
I did the DIY version on my 2002 Curvy, no noticable difference
Old 20-10-09, 07:08 PM   #6
sunshine
heres the cheap way
1. remove ECU
2. plug into computer
3. recode script on there to be more suited to your riding
4. reconnect on the bike
5. test ride
i has a curvey so i havent done it on an sv but i have done it for a mate on his track bike when he had a ecu which was easy enough to reprogram.
Old 20-10-09, 07:09 PM   #7
Dan
Old 20-10-09, 07:10 PM   #8
xXBADGERXx
Waste
Of
Time
And
Money
You want more speed , buy a faster bike . There is no cheap and easy way to gain anything truly massive on the SV I`m afraid to say .
Old 20-10-09, 07:14 PM   #9
Originally Posted by sunshine View Post
heres the cheap way
1. remove ECU
5. test ride
Perhaps you could post some pics of how you did this
Old 20-10-09, 07:15 PM   #10
ophic
ophic's Avatar
I did the DIY on my pointy - works but only has an effect at below half throttle and below 4000rpm (both must be true) - so utterly pointless as you don't really ride in these rev/throttle ranges on the SV. I took it off again, as it affects the neutral "map" and makes the tickover drop by 2-300 rpm - not good for winter. I think I noticed it made the bike slightly louder at tickover and low revs, but the effect is very slight. Doesn't improve the snatchy throttle at all.
The DIY job on a pointy consists of 1 20p resistor and 2 bits of heat shrink tubing. Pennies. Don't ever pay for one.
Silver SV650SK3, Fuel exhaust
Recommend me......... phil24_7 Idle Banter 17 11-01-09 10:48 PM
Recommend we have a 'Recommend me a...' forum _Stretchie_ Idle Banter 0 05-06-07 01:30 PM
recommend me a......'recommend me' thread CoolGirl Idle Banter 5 05-06-07 08:17 AM
Recommend me... mysteryjimbo Suits 6 02-01-07 09:08 AM
Recommend me... susan balthasar Bikes - Talk & Issues 0 09-01-70 08:34 AM
