Old 21-10-09, 07:58 PM   #1
asteer17
Unhappy Sv1000 magneto
Hi,
My Sv1000s (2004) is losing charge, ive been told its either the regulator or alternator. My 'mechanic' reckons its the magneto and says the magnets are loose on the magneto itself, i bought a fairly new 2nd hand part and he says thats faulty to cos they are slightly loose too. Im not sure he knows what he's on about :s
Can anyone tell me if the magnets are supposed to be slightly loose and if there are any known common faults for sv's to loose their charge, im fairly new to all this and have not had the 2nd hand bike very long,a month infact
Old 21-10-09, 08:59 PM   #2
Dave20046
Dave20046's Avatar
Default Re: Sv1000 magneto
Can you get hold of a multimeter? there's a simple test to check whether it's just the reg/rec or the more expensive stuff.
Old 21-10-09, 09:03 PM   #3
asteer17
Ive been told its producing charge but not quite enough to charge the battery, also ive been told the alternator is fairly new.
my 'mechanic' (dodgey back street garage) told me @1000 rpm its 10v and 6000rpm its 12v.
Ive spoken to a few authorized suzuki shops and they advised me its probably the reg/rec and they usually go after 5yrs approx.
Does this help?
Old 21-10-09, 09:08 PM   #4
Dave20046
Dave20046's Avatar
Regrec can go over any time period, independant garages are not necesarily dodgy.
If you have a multimeter (you can get them for £5 b&q style) then you can find out for sure. If not then the only other option I can think of is leaving it in your mechanics hands (or another mechanic)
Old 21-10-09, 09:11 PM   #5
asteer17
Thing is, i dont think he's too sure what he's on about, ive rang major bike shops and they are saying diff stuff to him, also he will not order parts to sort it out if its not the part needed, surely if he's running a business he should know what wrong and be able to sort it and order the right parts?? he's had the bike for 8 days now and im still no nearer to getting it back
Help.....
Old 21-10-09, 09:12 PM   #6
asteer17
do u know about the magnets on a magneto?
Old 21-10-09, 09:14 PM   #7
asteer17
he wants me to pop into his shop tomorrow to look at the magneto, can you tell me what to look for regarding multi meter readings to tell what the problem is like u said in your first post please??
Old 21-10-09, 09:16 PM   #8
asteer17
when i say he's the mechanic, he owns the shop (fairly young chap) and the 2 mechanics cant barely talk english
Old 21-10-09, 09:20 PM   #9
Dave20046
Dave20046's Avatar
To rule out the reg rec, when the reg rec is unplug the reg rec (3 plugs if I recall correctly) you need to measure the a/c voltage across the plugs. i.e you have plug's a,b & c. measure between a-b, b-c and a-c all readings should be above 75 (or possibly 85 my memory ain't brilliant) mine was in good working order and went well over 150. This means it's most likely your regrecs ****ed as it suggests everything pre regrec is working well.
As per magnets I haven't got a clue, never had a alternator or anything go on me only a reg/rec.
*touches wood*
Old 21-10-09, 09:23 PM   #10
Dave20046
Dave20046's Avatar
The above info is true (from what I remember anyway) for my 650 atleast , 1000s could be different. If you want to know if he's having you on ask him what readins he was getting from the battery, and from the alternator (3 wires going to the reg rec I mentioned) he should know if he's decided to strip down the magneto or whatever.
Sv650 magneto cover pillphil SV Talk, Tuning & Tweaking 4 18-08-09 01:22 AM
CDI Magneto Wiring DarrenSV650S Bikes - Talk & Issues 11 04-03-09 11:42 AM
Signal Generator and Magneto Grinch Stuff Wanted 5 25-11-08 04:57 PM
Magneto Cover andym8 Stuff Wanted 2 04-10-06 02:20 PM
SV1000 tricky Bikes - Talk & Issues 8 02-09-05 10:34 AM
