Old 01-11-09, 06:39 PM   #1
wow
Default Indicators
I have been thinking about getting a second bike but have decided against it and I'm going to get some some nice indicators for the SV instead and maybe a belly pan. I can't decide between these two.
http://www.mandp.co.uk/productinfo/5...cators/Bike-It
http://www.mandp.co.uk/productinfo/5.../On-Two-Wheels
Do you (normally) get the same ones for front and rear?
And what is it again I need to buy separately, relay thingy? Do I need two of those? (one for front and one for rear). Or am I better off not getting LED ones for front?
Lots of questions, any answers?
Old 01-11-09, 06:44 PM   #2
the_lone_wolf
Captain Awesome
the_lone_wolf's Avatar
Default Re: Indicators
I've yet to see a pair of LED indicators that offer the brightness and viewing angle of normal bulb types, they're there for a reason at the end of the day. If yhou do get then though you only need one "Flash-It" relay for the whole bike and I'd say having different ones front and back is just fine so long as they suit the lines
If you have the yellow covers you could do worse than a set of clear lenses and yellow bulbs from a newer year Suzuki model, they look much nicer but still offer the view of the stock ones
(•_•)
( •_•)>⌐■-■
(⌐■_■)
Deal with it...
Old 01-11-09, 06:53 PM   #3
TheOnlyNemesis
wait from buying a bike to indicators, huh
Old 01-11-09, 06:53 PM   #4
Dave20046
Dave20046's Avatar
I like the non chrome ones, the ones adverised are per pair so you'll need to by two sets. If you have a naked it's as simple as that. If you have a faired on you might need slightly longer stalked ones to protrude enough, however I'm posting in ignorance on that front as I've never bought stalked indicators for a faired bike (I have mirror ones).
You'll require an LED flasher unit (just one) it needs to be wired in in place of your old flasher unit (which is part of the sv's multifunction relay), just a case of snipping to wires and attaching the flasher unit across them.
I found my LED rear ones much brighter than my bulb ones on the curvy, that's the reason I replaced them. Couldn't see the bulbed ones when I followed my mate riding my bike in the sunlight, I find LED ones easier to see in sunlight. Agree with the clear lenses looking loads better though.
Old 01-11-09, 06:56 PM   #5
the_lone_wolf
Captain Awesome
The ones I had, if viewed directly face on they were great, very bright, but as soon as you move slightly to the side they were hopeless - bordering on dangerous
Looked very "aaaight" though
(•_•)
( •_•)>⌐■-■
(⌐■_■)
Deal with it...
Old 01-11-09, 07:02 PM   #6
Dave20046
Dave20046's Avatar
wow; I went for mini arrow ones for my curvey and thought 'these'd look great on a pointy', fair few months later I bought a pointy so tried it out. These are the longer stalked ones though on the rear as my tail tidy meant they'd be situated pretty close together if not.
Hope mine aren't, not had a complaint yet though (asked people on rideouts a few times), definitely agree with your 'there for a reason' point though it's worth considering before messing with them. My front led ones (integral with the headlight) were less visible so I added the mirror indis (aaaight ).
Old 01-11-09, 07:14 PM   #7
wow
Thanks for the replies guys. I might get the shorter black ones for the front and the longer ones for the rear as I have a tail tidy and I believe you can see them better if they stick out a bit more.
Old 01-11-09, 07:53 PM   #8
wow
I understand you can also get resistors, one for each indicator. Has anyone done that? They're cheap. Are they necessary? and instead of the relay or in addition?
Old 01-11-09, 07:54 PM   #9
Dave20046
Dave20046's Avatar
instead of the relay. Cheap relays are only like £5, one for the pointy I paid an extortionate £15 for as I needed it quick smart and could only get motrax from a dealer. Resistors aren't as good/tidy in my opinion, more of a work around.
Old 01-11-09, 07:57 PM   #10
mattSV
mattSV's Avatar
However resistors only cost me 17p each from Maplins and worked fine for the 5 years I had my SV1000
2000 - 2004 SV650S
2004 - 2009 SV1000S
Micron Front Paddock stand, Arrow-style LED indicators, Chrome Eagle-Eye indicators, Rear paddock stand Aluminium bobbins for swingarm.... lucky strike For Sale - Other Bikes and General biking items 12 27-08-09 12:00 PM
Remove front indicators space -Move indicators in headlights JanGoris SV Talk, Tuning & Tweaking 5 19-04-06 09:27 PM
Led Indicators H62 Bikes - Talk & Issues 6 17-03-06 04:56 PM
LED indicators 650newb Bodywork 7 28-02-06 05:42 PM
gsxr 600 indicators and sv k5 indicators (put down - drop) swamp SV Talk, Tuning & Tweaking 3 03-04-05 02:25 PM
