Old 14-11-09, 01:08 AM   #1
lazymanc
Default Fuel light permanently on
My 03 pointy fuel light has recently decided to stay permanently on, even with a newly brimmed tank.
I've done a quick search of the forum but I couldn't really find anything other than questions about tank range.
Any ideas?
lazymanc is offline   Reply With Quote
Old 14-11-09, 09:28 AM   #2
liamsimpson
Default Re: Fuel light permanently on
the pointy will do around 130 mile before fuel light comes on and then to play safe you have around 20 miles (ish).
Under the tank there is a big nut that bolts to the tank trace that wire back to the plug, unplug it squirt some WD-40 in it and plug back in and try it. If still no joy your level sensor might be broken or stuck??
Old 14-11-09, 12:03 PM   #3
bondwest
Any ideas?
Try filling it up with petrol.
Old 14-11-09, 01:06 PM   #4
lol that guy was funny, pitty he's strapped in his high chair now and cant reach the PC.
Old 14-11-09, 01:26 PM   #5
empty
The "level sensor" is just a couple of thermisors (heat dependent resistor) - you could measure the resistance across them, I suspect one (the lower one) will probably be open circuit. All of the rest of the electronics for the fuel light is in the clocks. If it measures OK at the tank end, there is probably either a broken wire or a short in one of the looms.
Hope this helps,
MT
Old 14-11-09, 01:32 PM   #6
lazymanc
Thanks liam, i'll give that a try.
Old 14-11-09, 02:08 PM   #7
CLARKYsv
CLARKYsv's Avatar
Would fuses or dodgy earths affect this?
No reading from the sensor... light comes on.... :S
Maybe.....
CLARKYsv is offline   Reply With Quote
Old 21-11-09, 12:37 AM   #8
lazymanc
Hmm, I checked the connections under the tank / sprayed with WD40 and all seem ok, but the fuel light problem persisted. It's now progressed into a dead speedo, although the lights on the dash and the rev counter are still working.
I've also had a burning smell coming from the front of the bike for a week or so but I just put this down to the roads being wet and dirty - it now looks like it's more than likely related.
I'm gonna check all the fuses and wiring around the seat and headstock and see if I can spot anything burnt out. Still got lights / power at the minute.
Old 21-11-09, 02:16 AM   #9
barwel1992
strange i think mines on the blink :/ goes on and off quite a few times aday
Fuel Light Skripthor SV Talk, Tuning & Tweaking 10 10-08-08 10:01 PM
Fuel light yorkie_chris SV Talk, Tuning & Tweaking 5 27-06-07 09:25 PM
gas light?(that'll be fuel warning light) Spanish Fly SV Talk, Tuning & Tweaking 9 08-06-07 05:45 PM
Replacement fuel light / fuel tap riktherider SV Talk, Tuning & Tweaking 7 14-05-07 06:41 PM
Fuel Light yellowsvs SV Talk, Tuning & Tweaking 13 21-06-05 11:37 AM
