Old 20-11-09, 11:48 AM   #1
Grant66
Grant66's Avatar
Question Clunking noise
I noticed a strange clunking noise comming from the gear change area of the bike (2002 Curvy S) last night. Might have been doing it for a while, just didn't put ear plugs in last night.
Clunking noise sounds like the clunk you get during a gear change (and comes from the same area). A clunk every few seconds (time varies), it stops when the clutch is pulled in or the bike is stationary. Drive is smooth otherwise.
Is this something that I should worry about? Does it sound expensive or just a clean up job? Not had chance to have a look at it yet, I suspect its some springy thing (stop me if I get too technical) thats sticking.
Grant66 is offline   Reply With Quote
Old 20-11-09, 12:06 PM   #2
davepreston
Default Re: Clunking noise
if ya can get over to mine today i'll have a look at it for you
will pm address
Old 20-11-09, 12:10 PM   #3
Dave20046
Dave20046's Avatar
Have you got oil in the bike?
Old 20-11-09, 12:12 PM   #4
jambo
jambo's Avatar
does the rate of clunk change with speed?
If so, I'd suspect a corroded/tight link in the chain. Check both front & rear sprockets for wear, and full compliment of teeth. Pulling in the clutch takes off the load off the final drive so a noise from it can be reduced that way.
Jambo
Old 20-11-09, 01:02 PM   #5
lee67
+1
Old 20-11-09, 01:51 PM   #6
vardypeeps
Id go with a tight spot in the chain or it could be a missing sprocket tooth at worst?
Old 20-11-09, 02:10 PM   #7
Grant66
Grant66's Avatar
it has oil
I'd expect it to be more consistant (time wise) if it was the chain, it seemed to get less often when speeding up. Although I only noticed it when going slow.
Earliest I can look at it is tomorrow morning, I'll report back. Thanks for the heads up on the chain I'll give it a good looking at.
Old 20-11-09, 02:14 PM   #8
barwel1992
the thing is with wind noise you carnt realy tell if it gets louder with speed, ifyou have a abba stand or padock stand maybe run it just with clutch bite (go up through gears so gets faster each time but no throttle or it may end up off the stand) and see it you can figure out where the noise is coming from (exactly)
Old 20-11-09, 02:28 PM   #9
Grant66
Grant66's Avatar
I've got an ABBA, thought of doing that but talked myself out of it with thoughts of going through the back of the garage
Old 20-11-09, 02:51 PM   #10
barwel1992
haha well zip tie the front brake on then i have done if a few time EG loobing the chain
total mechanical amateur - Clunking noise when accelerating? Any Ideas TechJinx SV Talk, Tuning & Tweaking 10 23-06-09 01:27 PM
It still makes that clunking fork noise. Tony_BLY SV Talk, Tuning & Tweaking 29 01-03-09 10:48 AM
clunking noise under braking nik_nunez SV Talk, Tuning & Tweaking 24 28-08-08 04:24 AM
Clunking noise on GSXR750 rubberduckofdeath Bikes - Talk & Issues 8 06-06-08 05:19 PM
clunking chain noise steveg Bikes - Talk & Issues 4 23-03-08 10:39 PM
