Old 22-11-09, 11:53 AM   #1
Gnome
Default Has anyone used these indicators?
Blatant rip-offs of the Motrax ones, but look decent enough:
http://cgi.ebay.co.uk/Motorcycle-14x...item414a0c2550
Old 22-11-09, 12:04 PM   #2
Rob969
Default Re: Anyone used these?
looks like there worth a go at that price
Old 22-11-09, 12:08 PM   #3
Gnome
Exactly what I was thinking.
Have mini indicators on the back at the mow, and some old flat flush-mount ones on the front.
Due to the wattage of the bulbs, it means resistors were fitted in place to bring the flash-rate down, but it doesn't seem to have worked, and the bulbs have a tendancy to blow!
So looking for some brighter LED ones, and sticking a proper relay in there too.
Old 22-11-09, 12:23 PM   #4
LK-SV
Agreed ............. if your prepared to wait (delievery from China takes forever) - could be worth a punt ....
On the otherhand ... if you get one that breaks ...... or doesn't work ....... and you fail to find them again ........ it could be an expensive mistake to go cheap when you have to replace all 4 again (if you want matching) !!!
Old 22-11-09, 12:31 PM   #5
Rob969
short stalks for the front, long for the back, think i might order some later on
Old 22-11-09, 02:53 PM   #6
wow
Default Re: Has anyone used these indicators?
They look like mine, I have the long stalk version.
Got mine from M&P for 19.99. So this is a v good price. http://www.mandp.co.uk/productinfo/5.../On-Two-Wheels
It said twowheels (make) on the M&P website but when i got them it said Tech 7.
Mine are nice looking and bright.
Here's the thread which has a picture of the same ones (or similar ones) fitted to a bike so you can see what they look like.
http://forums.sv650.org/showthread.p...icators&page=2
Old 22-11-09, 02:56 PM   #7
wow
Had my LED indicators fitted today. Used 6 10watt 10ohm resistors, 4 at the front and 2 at the back, it's a bit of a dark art those resistors as my friend who fitted them thought 4 would be enough (thanks to a tip from someone on here).
The resistors are £0.46 each in Maplins. No need for a relay.
Old 22-11-09, 02:59 PM   #8
2hys
have they got resisters built in? or do you have to sort that out for yourself?
!just read the above post!
Old 22-11-09, 03:04 PM   #9
wow
They are separate if you go to the M&P website choose your indicators they also have LED resistors on there. You have to make sure tho that your resistors are for led indicators if you get them from a bike shop. REsistors for normal mini inidicators won't work.
Old 22-11-09, 10:25 PM   #10
thefallenangel
if they are the 120 degree off set pins on the bulbs you get away with forcing 180 degree opposite pin bulbs in of a higher resistance as a cheaper option again, i've done this with my motrax indicators as apparently the bulbs are harder to get hold of.
Micron Front Paddock stand, Arrow-style LED indicators, Chrome Eagle-Eye indicators, Rear paddock stand Aluminium bobbins for swingarm.... lucky strike For Sale - Other Bikes and General biking items 12 27-08-09 12:00 PM
4x Indicators Aidan Stuff Wanted 0 22-06-09 05:04 PM
Remove front indicators space -Move indicators in headlights JanGoris SV Talk, Tuning & Tweaking 5 19-04-06 09:27 PM
Led Indicators H62 Bikes - Talk & Issues 6 17-03-06 04:56 PM
gsxr 600 indicators and sv k5 indicators (put down - drop) swamp SV Talk, Tuning & Tweaking 3 03-04-05 02:25 PM
