Old 26-11-09, 01:45 PM   #1
SUPERSTARDJ01
Default Engine oil?
Hi,
In terms aof engine oil what do these mean? -> API, SE, SF , SG, API, SH, SJ, JASO, MA.
Also what is in your opinion the best SAE engine oil for a high reving engine?
Old 26-11-09, 05:45 PM   #2
embee
embee's Avatar
Default Re: Engine oil?
In the simplest terms
API = American Petroleum Institute - a body who oversees the testing and rating of all stuff to do with fuels and oils
SG, SH etc = the wear protection standard which the particular oil meets. The "S" stands for spark, there is a similar "C" rating system for compression ignition (Diesel). Basically the second letter goes in alphabetical order, and any classification should supercede an earlier one (SH is at least as good as SG etc)
JASO = a similar institute to the API but based in Japan I believe. JASO-MA is a test specifically to demonstrate that an oil is suitable for use with wet clutch systems (as used in most but not all bikes).
SAE (another institute) is a rating system typically quoted when referring to an oil viscosity. It usually has two ratings (multi-grade), one when cold (zero F or -18C) which is the "W" number, and one when hot (around 100C), so you get 10W-40 for example. The actual numbers refer to units of viscosity, but different units at the 2 temperatures just to confuse things.
As a rule of thumb, use the lowest viscosity the engine manufacturer recommends for the ambient temperature you'll be using it in. Most bikes will recommend a 10W-40 or a 10W-30, but check the manual.
Bike oils do differ technically to car oils, there are typically extra anti-wear additives to deal with the integral gearbox requirements (cars generally have separate gearboxes), and there's the aforementioned wet clutch business.
Oils can be produced in a variety of ways, with different properties resulting. They can be straight from mineral sources ("mineral"), or synthetically produced ("synthetic") or can be partly ("semi") synthetic (that's the very simplified explanation anyway). Most road bikes will be happy with a semi-synthetic. Fully synthetics can offer extended service intervals and better stability at very high metal temperatures, but are often more than many engines actually requires in real life.
Engine Breaking? Hopefully not. Engine braking - is that OK? butterick99 SV Talk, Tuning & Tweaking 14 12-09-09 10:31 PM
Dead Sv Engine or Engine block.... Andy Jeffries Stuff Wanted 6 15-08-09 07:46 PM
Engine braking... any hazzards engine wise? John 675 SV Talk, Tuning & Tweaking 21 28-03-08 07:20 PM
What Engine Oil? Girth SV Talk, Tuning & Tweaking 7 11-05-07 08:39 AM
Engine out or not ? Banus SV Talk, Tuning & Tweaking 18 05-01-06 11:22 AM
