Old 06-12-09, 02:25 PM   #1
rowdy
rowdy's Avatar
Default NC24 non starter
Well the old viffer has been sitting in the shed for far too long and I am starting to look for a few bits and pieces on ebay to try and get the old girl up and running again.
It's been left redundant ever since the summer of 03, when the missus suggested that I buy a new bike.
The problem that I had with it before I parked it was a total loss of ignition. I bought it off a mate, and he said that he thought the ignition solenoid was on the way out, so I replaced the solenoid, and the battery before giving up on it, as these didn't cure it.
Not long before it was completely dead, it wouldn't start of its own accord and needed bump starting, but then, after a while, not even that would kick it into life.
In the end I could turn the ignition on, but would get no warning lights on the dash at all, and I could even pull the ignition key out without switching the ignition back to the off position.
So, my question is, is the most likely suspect just the ignition switch, or would it likely be something else that caused the loss of all warning lights and ability for the starter to engauge etc. like the reg/rec, coils, or cdi unit.
Old 06-12-09, 03:55 PM   #2
ThEGr33k
Default Re: NC24 non starter
If you turn the key and the bike basically stays turned off id be willing to say yes, the ignition switch.
The only think that can stop the starter turning is the immobiliser built into the ignition. If you short the solenoid it should turn over.
HTH a little.
Old 06-12-09, 04:56 PM   #3
Wester
Hope this isnt outside the rules, but you may find http://400greybike.info might be able to help.
Old 06-12-09, 05:00 PM   #4
Alpinestarhero
I dont see why it's against any rules - in any case, thats a great source of info, I used it a fair bit when my dad was in need of info for his NC24. Incidentally, I can't think what to suggest to you rowdy, other than try and bypass the ignition switch. If you can pull the key out while the switch is in the "on" position, then it would suggest thats a bit goosed anyway.
Old 06-12-09, 05:19 PM   #5
Bad wire or the switch. Check the switch is getting fire up from the main fuse, go from there. Standard electrical inconveniences, trace the route current must take and check it is there at each step until you find where it isn't.
Old 06-12-09, 06:03 PM   #6
fastdruid
fastdruid's Avatar
Very likely ign switch but other things may be at fault.
The problem I had with my track NC35 was a bad earth, remove the battery to frame lead, put some copperslip on the tab and bolt and retighten. Repeat for the loom to earth tab.
The SV in comparison has a connector in the wiring loom that connects to the battery / earth, the NC's *have* to go through the frame.
Druid
Old 09-12-09, 09:04 PM   #7
rowdy
rowdy's Avatar
Reet, won an ignition switch on ebay tonight, but lost out on a reg/rec. looking on ebay there are a load for about £60 new, and also some for £10 to £20. Now, the cheapo ones say from hong kong, but when I looked at one of them (for £1 it said the shop was wemoto, so would it be wise to trust a cheap one?
Also it was listed as nc30, nc35 fitment along with various cbr's so wondered whether it might fit an nc24?
Old 09-12-09, 09:07 PM   #8
If battery is charged then reg-rec is not problem.
Old 09-12-09, 09:14 PM   #9
rowdy
rowdy's Avatar
Aye, batterys probably shagged, bought it new 6 year ago and it didn't resolve problem so haven't started the bike since. Just thought I'd get a few parts to cover as many likely suspects as poss at once rather than keep going out and fannying around with it.
So, cheapo reg/rec, go for it or avoid like a pro with a dose?
Old 09-12-09, 09:15 PM   #10
Reg rec, dunno.
But if battery is knackered then there's no point trying anything else. Replace/charge and pray that and see if it works.
VFR400 NC24 update. Alpinestarhero Bikes - Talk & Issues 31 01-07-09 07:17 PM
FOR SALE - VFR400 NC24 D Reg geodudeft For Sale - Other Bikes and General biking items 2 10-04-09 05:25 PM
Honda vfr400 nc24 BBadger Bikes - Talk & Issues 20 13-01-09 03:12 AM
Sourcing NC24 Head gasket Grinch Bikes - Talk & Issues 9 12-10-08 12:25 PM
My Dad's NC24...again... Alpinestarhero Photos 3 05-10-08 10:17 PM
