Old 02-01-10, 04:01 PM   #1
Red Herring
Red Herring's Avatar
Default GSXR 600 K4 forks apart
Folks, apologies if this has been asked before, I did try the search facility but couldn't find what I needed.
Been trying to take my forks apart and can't work out how to get the top cap off. Normally you just push the spring down, hold the damper rod and unscrew it but on the GSXR K4 fork the preload adjuster seems to also be threaded onto the damper rod. I've undone the end cap but it won't come off with the adjuster still in situ. I've tried using a little force to unthread it but not moving, before i try any harder does anybody know if I'm missing something?
Thanks. RH
Old 02-01-10, 06:37 PM   #2
Default Re: GSXR 600 K4 forks apart
On SRAD forks you need tool to compress spring, then you hold preload adjuster with one nut and undo locknut with another. Whole cap assembly then spins off damper rod. That is also showa so can't see it being massively different.
Old 02-01-10, 07:44 PM   #3
Red Herring
That's how I've always done all my other forks, but on these the compression adjuster also seems to be threaded onto the damper rod so as you unwind the end cap the adjuster disappears down into the cap (as if you were applying more preload).
Old 02-01-10, 07:52 PM   #4
zadar
Most like you having preload adjuster holder unscrewing. You are not suppose to put wrench on preload adjuster but on holder, which is silver part on underside of cap. You hold that part and undo nut right under it.
If your silver part is turning with blue preload adjuster you will have to fix it, tighten it against cap body.
Old 02-01-10, 07:59 PM   #5
zadar
Black painted square is nut. hold part red arrow points to (preload holder) and unscrew nut. You need two 17mm wrenches.
Old 02-01-10, 09:11 PM   #6
Red Herring
Thanks Zadar, they've come straight apart. Can't believe I missed that, having said that you don't half have to pull the spring down to get to it!
Don't suppose you happen to know what the standard fork oil height is do you?
Old 02-01-10, 10:33 PM   #7
zadar
You do have to compress spring to get to nut.
I set level at 125mm.
Old 02-01-10, 10:44 PM   #8
Red Herring
Thanks mate, I'll use that as a base setting.
Old 02-01-10, 11:57 PM   #9
zadar
Just make sure that silver part is screwed in to gold part good. If it goes up/down with blue preload it is not good. See on top of cap part that sticks out of blue with screw adjuster in it. That is same part, silver under cap, all one piece.
Hold gold cap with wrench and tighter silver part against it, or at least check if loose. I think you may loosen it first time.
There is also procedure how to screw cap back on damper rod to make sure your rebound adjuster works.
Old 03-01-10, 10:10 AM   #10
Red Herring
Cheers, I made a note of where the lock nut was before undoing it and i think the main thing to watch for on reassembly is that the rebound adjuster is screwed out before tightening back up, otherwise you might compress the rod. I just couldn't believe how much crud there was in the bottom of the forks. I'd noticed the action hadn't been so good over the last few months but it's embarrassing just how bad I'd let it get!
GSXR Forks / I know its on here. SV-net SV Talk, Tuning & Tweaking 4 16-07-09 03:20 PM
GSXR 750 k4 wheel with GSXR 600 K7 forks Bunks Bikes - Talk & Issues 12 05-05-09 06:36 PM
GSXR Forks tactcom7 Stuff Wanted 0 05-04-09 01:16 PM
K7 GSXR 600/750 or K8 GSXR 1000 Forks shelleyamy SV Talk, Tuning & Tweaking 17 04-07-08 07:51 AM
gsxr k6/7 forks maff SV Talk, Tuning & Tweaking 7 10-02-08 06:02 PM
