Old 14-01-10, 11:29 PM   #1
starsky72
Default Which SV; the far better looking curvy or the badly built pointy?
Just been reading through a few threads and saw the following comment
which sv the far better looking curvy or the badly built pointy?
Now I like the look of the pointy, however was interested to see the comment about poorer build quality.
Is there a post/stick on these forums that lists the model numbers and the differences?
Stu
Old 14-01-10, 11:34 PM   #2
davepreston
Default Re: which sv the far better looking curvy or the badly built pointy?
99-02 curvy carbed models
2003 pointy k3 injection diferent rear subframe to following pointies
2003-07 pointy injected s
07> pointy sport just name change
hth
ps points got a black frame at some point but cant remember the year
Old 14-01-10, 11:38 PM   #3
davepreston
its all the same budget suzuki build quality eg rusty bolts and no grease after that the carbed sv's are easier to fix (less electrics to f up)
Old 14-01-10, 11:38 PM   #4
I don't think anyone has ever compared the two models before. We all just accept that whether they are curvy or pointy they are both brilliant.
Old 14-01-10, 11:56 PM   #5
5hort5
It's rubbish I have owned both and the pointy is fine, the curvy is a dated lady now and needs more care. Suzuki just can't make fixings like bolts for any bike.
5hort5 is offline   Reply With Quote
Old 15-01-10, 05:08 AM   #6
Red Herring
Red Herring's Avatar
Any bike will rust if neglected enough, the trick is not to let it get bad in the first place. If you use your bike every day, especially at this time of year, then you're going to have your work cut out to keep it smart, but there are some great sprays and cleaners on the market. I guess in the end it's just a question of how much you love her.....
Old 15-01-10, 01:08 PM   #7
Default Re: Which SV; the far better looking curvy or the badly built pointy?
Newer pointy has twin plug heads, avoid.
Old 15-01-10, 01:11 PM   #8
starsky72
what problems does that pose, is it for reduced emissions?
Old 15-01-10, 01:12 PM   #9
Yes. Means you pay more when you need to change them and if you want to tune it the results are far reduced.
Old 15-01-10, 01:16 PM   #10
starsky72
which year was the "twinspark" introduced then?
Why does riding a bike make you want to pee so badly? Bear Idle Banter 29 05-05-08 08:06 PM
pointy rear light with built in indicators sv650nutter149 Stuff Wanted 0 05-04-08 07:53 PM
Curvy Mirrors with Built in Indicators fenris SV Talk, Tuning & Tweaking 14 26-02-08 08:40 PM
Running badly in the wet Addick SV Talk, Tuning & Tweaking 14 09-12-05 08:40 PM
its ok to drive badly! official! busasean Bikes - Talk & Issues 11 18-05-05 04:48 PM
