Old 04-02-10, 10:12 PM   #1
Default Delivery pipe for Scottoiler
I must have had the delivery pipe pressed on to the disc too hard because it has worn right through the side of the pipe
Does anyone have a spare one?
Old 04-02-10, 11:34 PM   #2
Luckypants
Luckypants's Avatar
Default Re: Delivery pipe for Scottoiler
A few pennies from the Scottoiler website, pack of three.
Old 04-02-10, 11:42 PM   #3
Sweet. Cheers
Old 05-02-10, 12:08 AM   #4
Stu
Trinity
Stu's Avatar
or a wd40 etc. straw
Old 05-02-10, 12:09 AM   #5
Stu
Trinity
Stu's Avatar
You're oiling your brakes?
Old 05-02-10, 02:51 PM   #6
What I meant was, the disc part of the sprocket. As opposed to the teeth. Yeh that's what I meant
Old 07-02-10, 08:12 AM   #7
larigos
I used a length of brass tube from the local hobby shop. Didn't wear out!
Old 07-02-10, 04:18 PM   #8
Stu
Trinity
Stu's Avatar
They don't wear out. If it's touching the sprocket it might wear done a bit and it might wear down a bit then it would stop touching. If it's touching more than that you should se it up right.
If it's disappeared then it's got caught in the chain. I would rather have something softer than brass if that happens.
Refitting standard pipe: link pipe? Jay1 SV Talk, Tuning & Tweaking 6 17-04-08 09:51 AM
Fitting a Scottoiler delivery pipe. Lozzo SV Talk, Tuning & Tweaking 14 16-01-08 06:41 PM
Delivery from the USA mister c Bikes - Talk & Issues 10 31-08-07 06:57 PM
£10 Delivery and this is what you get. PsychoCannon Idle Banter 13 06-02-07 08:44 PM
Mounting Scottoiler delivery tubing walnuts SV Talk, Tuning & Tweaking 14 13-06-06 09:26 AM
