Old 06-02-10, 02:46 PM   #1
steveg
steveg's Avatar
Question Play in front brake disc
Hi
Just had bike MOT'd today which it passed ok.
Gave the bike a oil & filter and general clean over and noticed that one of the front disks has a fair amount of play in it .
It appears that the bobbin has play and can moved disk about 1mm front/back and side / side
This can't be right ? Should this have passed the MOT ?
Can I replace bobbins or is it new brake disks
Or is it Safe to leave as TBH brakes are fine ?
Just fitted new tyres / brake pads / worm drive , kind of wishing I had got rid of the bike before spending what willl 500 quid if I do need new disks ...
Cheers Steveg
ex - red sv650s 06 reg
Now Triumph sprint 1050 ABS 05 Reg
AKA Papa Smurf
steveg is offline   Reply With Quote
Old 06-02-10, 03:00 PM   #2
SV650Racer
Default Re: Play in front brake disc
Its not ideal but isnt an MOT failure.
I had this on my stock discs on my racebike. They were fine for a season and then I changed them. The brakes worked fine apart from they clanked when I rode over a few bumps at low speed. They ended up being just like a fully floating set.
Keep an eye on it and if you start to get a judder from the front brake then its time to consider changing the disc. You can change just one disc too if you have to because of budget.
Used discs come up every now and again on ebay just be aware you could end up buying warped ones!
Old 06-02-10, 05:00 PM   #3
NedSVS
Originally Posted by steveg View Post
Hi
Cheers Steveg
I replaced the bobbins on my curvey, when the wavey spring washers broke up, with a kit from Stealth Products. I have a spare set as I changed to Honda wheels and never used the second set I bought for spare wheels. I payed £42.83 for them but you can have them half price if you want them. There are 12 bobbins and more than enough wavey washers and retaining circlips. If you are interested then check with stealth that they are the sme for your pointy and PM me.
Old 06-02-10, 05:05 PM   #4
NedSVS
Should have said, Stealth Producs 01142 570111 or email dcrooks@ukonline.co.uk
Old 06-02-10, 06:30 PM   #5
steveg
steveg's Avatar
I've sent a email to stealth , will get back in touch if curvey bobbins etc fit pointy
Cheer Steve
AKA Papa Smurf
Front Brake Disc-Ilex Old Git SV Talk, Tuning & Tweaking 0 06-09-09 01:40 PM
curvey front brake disc lennon38 Stuff Wanted 0 12-08-09 12:02 AM
Front brake disc bolts DaveW_42 Stuff Wanted 1 18-06-09 01:47 PM
front brake disc question Ryest SV Talk, Tuning & Tweaking 5 31-10-07 09:02 PM
front brake disc leemole Stuff Wanted 1 17-08-07 06:52 PM
