Old 06-02-10, 06:08 PM   #1
sam anon
Default Curvy signal generator anyone?
I'm after this to get my SV working again.
Hopefully someone on here has one!
Old 06-02-10, 06:13 PM   #2
Default Re: Curvy signal generator anyone?
Maybe, I'll check
Old 06-02-10, 06:41 PM   #3
sam anon
Great, thanks for looking, and god, this forum is so useful, and hopefully saves alot of people time, hassle and money.
Keep it up everyone!
Old 06-02-10, 06:46 PM   #4
I tihnk I sold my spare to nadinedebiene when her generator packed up. Why don't you PM her and get signal generator from her knackered genny? You will need to do bit of soldering.
If you want you can post me both and I will swap them for you
Old 06-02-10, 06:58 PM   #5
sam anon
I will do, thanks for getting back to me. I've also been offered one by pm so have a couple of optiions.
Is there anyway of identifying which part is the faulty one, the signal generator or the generator coil bit?
Old 06-02-10, 07:04 PM   #6
One will cause you to have no spark, other one will mean your battery goes flat. Failure of either is pretty rare
Old 08-02-10, 01:21 PM   #7
sam anon
So far no joy!
It's part "1" on this link if that helps?
http://www.alpha-sports.com/suzuki_parts.htm
Surely this can't be an SV specific part? Does anyone know if it is used on any other Suzukis?
Old 08-02-10, 01:29 PM   #8
Neeja
The link doesn't work on that - it just links to the main page since you've got to navigate through it in the frames to get to the specific bit. If you're on about part 1 on the magneto page (the big coil of wires that you bolt into the alternator cover), I've got one knocking about in my garage from my lunched engine. Strictly speaking I've got an entire engine, so if it's not that bit, I can almost guarantee I've got it anyway.
Old 08-02-10, 01:35 PM   #9
sam anon
Working link! It's part "1".
http://www.alpha-sports.com/spst/2000%20SV650,S/41.gif
Old 08-02-10, 02:21 PM   #10
That is the stator and it is the pulse generator AND the generator.
One tells the ignitor box when to fire the spark, the other charges the battery. Which is your problem?
Signal generator pick up coil!!! EssexBoy SV Talk, Tuning & Tweaking 0 15-06-09 10:02 AM
Signal Generator and Magneto Grinch Stuff Wanted 5 25-11-08 04:57 PM
How do you get the best TV signal? ooger Idle Banter 19 03-11-08 09:37 AM
Signal Generator for sv650 '99 Curvy mikeSV Stuff Wanted 4 24-07-08 10:35 PM
Signal Resistors... ahlb0018 SV Talk, Tuning & Tweaking 7 17-02-05 10:02 AM
