Having problems fitting the lower bearing race into the frame. Its a taper bearing I'm fitting, not the OEM caged ball bearings.
I've popped out the original OEM lower race easily enough Original OEM bearing number is SAC3055-1 bearing size is 30 x 55 x 17 The replacement is 32006 bearing size is 30 x 55 x 17 The roller bearing has been pressed onto the bottom yoke, so that's fine But I cannot fit the lower bearing race into the frame far enough, so that the yoke is sitting in the right place. I've tried using the threaded rod with a locknut at one end and trying to press the race into the frame by turning a nut at the other end, as per Haynes manual. Even ****ting the race really really hard only gets it to about 10mm from where it should be. It shouldn't be such a tight fit should it ![]() Before anyone says, I haven't been hitting the bearing race directly. Any ideas on why I cant fit this?
We're riding out tonight to case the promised land Make everyday count RIP Reeder - Jolly Green Giant and comedy genius Last edited by maviczap; 08-02-10 at 02:59 PM. |
Have you got it c*cked off to one side?
I warm frame up by wrapping headstock in a rag and pouring hot water on it. Gives a tiny bit more clearance. Feel above race, there is a step the bearing must seat against. Are you on it? If not is the gap to it even?
#3 | |
I popped the race out, an you could see the score mark where it had got to in the frame. Hot air gun ?
Yeah hot air gun or water from kettle will heat it.
If it has scored like that then it must not have been going in evenly. Use the old race as a driver
Good afternoon all.
These can be a sod to get in squarely. I use a blowlamp to gently heat the frame, & use plenty of grease on the frame & the outside of the bearing race. This will usually do the trick. You ideally need to have something of the correct diameter to drift the new bearing race into position. An old bearing race that's had it's diameter ground down, so it doesn't stick in the frame is ideal. The problem is your old race, being the caged ball type isn't hefty enough to use a drift againt the 32006 race. So, you'll have to find something suitable. Cheers. |
Cheers YC and Spanner man. I think a bit of warmth might help here, although if I'm going to be using the hot air gun, then I'd better remove the tank!
Bloomin frustrating I can tell you
YC & Spanner Man it worked! With the application of heat from the gun the bearings almost flew in. Took as long to remove the tank as it did to drift the bearings in.
Why couldn't it have been this easy this morning ![]() Top tip, I used an SV oil filter wrench mounted the wrong way round on a long socket extention bar as a drift. Greased both bearings as Mr Suzuki seem to have forgotten to do the top one when he made my Sv ![]() I owe you 2 a pint, as I was on the point of ring my local bike shop ![]()
Good evening all.
Glad to hear it's sorted. Cheers. |
#9 |
FWIW I just used hot water and didn't bother removing the tank, did use 4 kettle loads though (one to remove each bearing and one to insert the new one).
![]() Druid
'00 SV700S - '94 RVF400R - '97 RVF400R - '88 VFR750F |
#10 | |
![]() ![]() Thank godness for the Aldi hot air gun I bought ages ago, for those just in case moments ![]() GSXR top and bottom yoke installed now, so sometime this week some install pics
Head Bearing Removal | svdemon | SV Talk, Tuning & Tweaking | 3 | 30-05-09 07:22 AM |
Head Bearing problems | pete m | Bikes - Talk & Issues | 8 | 28-04-09 11:00 AM |
head bearing nut question ? | bad-sv650 | SV Talk, Tuning & Tweaking | 21 | 27-01-09 10:59 AM |
Wheel Bearing Inner Race Removal: | MrMessy | Bikes - Talk & Issues | 11 | 15-11-08 10:04 PM |
head bearing nuts | kcowgergmm | SV Talk, Tuning & Tweaking | 4 | 12-08-07 02:07 PM |
