Old 09-02-10, 09:27 PM   #1
Stimpy
Talking Advice on buying a new SV1000s
Hi all,
First post here, i'm looking at getting an SV1000s '04 at the weekend and was wondering if you could give me some advice on what things to look out for that can be dodgy on an SV; common problems/faults/damage etc. I've got a Bandit at the moment so am used to poor suzuki build quality n all.
Any help would be greatly appreciated! And if I get it I hope to see you all on here more often.
Cheers,
Old 09-02-10, 10:50 PM   #2
Paul the 6th
Paul the 6th's Avatar
Default Re: Advice on buying a new SV1000s
if you haven't already, I'd recommend a test ride... The engine feels ropey as feck below 3k revs but this is a characteristic of all litre twins apparently (honda vtr sp2's are meant to be astonishingly bad below 3k revs but what do you expect from a superbike)...
Mine has been bulletproof to be honest (but now that I've said that I'll put money it being a big pile of bits when i get home)... Have a look around the clutch side to see if any brake fluid has leaked (hydraulic clutch) mine did in summer but hasn't done it since - I think it might have been from heat in the garage making seals & bits expand slightly enough for it to seep.. Brakes are generally good stoppers but check for usualy stuff like pads releasing and consistent bite etc... All the other usual stuff as well actually, does the front suspension compress and rebound nicely without any lumps or knocking, if possible check the head bearings with front wheel off the ground (it's all in the biketrader buyers guide thing)..
Sure someone else will be along in a minute with some useful info
welcome along by the way
Old 09-02-10, 10:57 PM   #3
Ratty
Ratty's Avatar
Is it a K3 or a K4 ? You can tell by the shape or the side panels/ lower sub-frame / deeper riders seat, or if it's original paint, a K3 will have suzuki written on the tank. The K3's had more problems with dodgy knocking bearings, clutches and clutch slave cylinders. Other common problems are total elec failure due to a burnt out green elec connector under the airbox. You could look for early signs of trouble. Also check the rear exhaust gasket into the collector box which can fail regularly. These are all well documented at www.SV-portal.com
I've had to change the exhaust gasket on mine but it's been ace otherwise.
Hope this helps
Ratty
"I can see Paradise by the SV's light"
TCX Competizione S boots saved my foot .
Ratty is offline   Reply With Quote
Old 09-02-10, 11:07 PM   #4
Stimpy
Hi guys, thanks for the replies. Yes its a K3, its only done 10k and i've had loads of pics through and all looks well, but pics only say so much.
A stupid question but I cant find a Haynes manual for the 1000 only the 650? Is the 650 worth getting as their pretty much the same.
Cheers.
Old 09-02-10, 11:17 PM   #5
ophic
ophic's Avatar
Cheers.
Don't think there is one for the 1000. The 650 is a much more common bike, hence there is a manual for these.
They look similar, but that's about it. 1000 has better suspension, better brakes, it's a bit heavier and some people say less flickable - basically, it handles different. It's more vibey at low rpms.
Silver SV650SK3, Fuel exhaust
Old 09-02-10, 11:30 PM   #6
650 & 1000 share very little other than styling and a few incidental parts, a Haynes for the 650 won't be ideal. Suzuki's own manual is good however, (specific supplemental manual for the naked). As mentioned above some early ones had a problem with the clutch cylinder seals - I wouldn't worry too much about that as the chances of finding one of an early enough age that's made it this far without being attended to are slim. Some early bikes knocked a bit, same deal as above, it's not likely you'll find one that's made it this far un-noticed - unless it's knocking don't worry about it.
If it's in need of a service they can feel as rough as a very rough thing indeed, that said being as it's a big twin smoothness isn't it's defining trait - but I rather like it like that.
Fuel consumption can have you looking for a hole in the tank - twins are not efficient.
Engine paint falls off and leaves the outer casing with proper Swiss cheese looking pits in them.
PS. It's a fantastic motorcycle - you'll love it!
Old 10-02-10, 12:23 AM   #7
Haynes make a manual for the TL1000S which is close enough. Calipers are GSXR600 K1-3. Forks you can follow same service guideline as K1-K3 or SRAD, they are similar internals.
But that is if you can't find the factory manual
Old 10-02-10, 10:28 AM   #8
Stimpy
Ah cheers guys thats great. Will let you know what the bike was like after i've seen it! Cant wait am getting all excited like a kid at xmas!
Old 10-02-10, 10:30 AM   #9
Paul the 6th
even if you don't buy it mate, there's still plenty of non-sv owners on here - pop along to your local meet (south & west surfers is your local section I think?)
Old 10-02-10, 10:47 AM   #10
Not really.
Thats like saying they don't do a Cagiva Raptor manual but the engines a TL1000S, go buy that.
Advice on buying an SV please? BUTTYBIKER Bikes - Talk & Issues 11 14-11-08 10:17 PM
Advice on buying please. El_Guapo Bikes - Talk & Issues 14 04-10-08 05:32 PM
Buying Advice svgirl78 Bikes - Talk & Issues 10 11-07-08 03:42 PM
buying advice (which one) hovis Bikes - Talk & Issues 25 13-02-08 10:04 PM
Advice on buying an SV. TheStudent SV Talk, Tuning & Tweaking 2 22-04-07 07:37 PM
