Old 17-02-10, 04:59 PM   #1
Stu
Trinity
Stu's Avatar
Default How do you get the last piston out?
of your calipers
Old 17-02-10, 05:00 PM   #2
fastdruid
fastdruid's Avatar
Default Re: How do you getthe last piston out?
Pump them against something so they are a mm from popping, remove the something, remove the pistons.
This may be tricky if you have already removed one.
Druid
Old 17-02-10, 05:01 PM   #3
Grips covered in thick cloth
or
http://www.pvrdirect.co.uk/productin...?catref=VS1806
Old 17-02-10, 05:07 PM   #4
Stu
Trinity
Stu's Avatar
Answer: With more brute force
via Standing on the caliper and 2 hands on the pliers.
Was using 3 dust seals round the piston to protect it as I'm replacing them anyway - only damaged the last couple of mm of the piston - should be reet
Old 17-02-10, 05:13 PM   #5
Stu
Trinity
Stu's Avatar
Druid
Yeah I thought I did that - obviously not pumped them out enough. especially the first ones to pump out as I thought they would be easy
that's what I was doing - the green dishwashing scruber clothes without sponge was quite goodlooks good - but for the number of times I would use it and by they time you realise you want it - it's too late.
But thanks anyway
Old 17-02-10, 05:15 PM   #6
2hys
When youve done yours can you come here and show me what you did! Mine need doing but scared to touch them cos there either done right or there dangerous!!
Old 17-02-10, 05:17 PM   #7
Luckypants
Luckypants's Avatar
I think it was xXBadgerXx posted a good tip the other day. Put a few cable ties tight around the protruding piston, then you can grip them with mole grips / stilsons without damaging them. Then twist and ease out...
Old 17-02-10, 06:31 PM   #8
Stu
Trinity
Stu's Avatar
Yeah I saw that & tried it. the ziptie came off too easily for me but it gave me the idea of using the seals.
Old 17-02-10, 07:40 PM   #9
ricky
your not far from me, if you dont get help pop up im in rochester
Old 17-02-10, 07:44 PM   #10
punyXpress
punyXpress's Avatar
Pop the other piston/s back in & lock them there.
Reattach line & use lever to pop sticky one out.
Now: Street Triple R
High compression piston kit weecorey Mini-Twins 32 10-12-09 09:37 AM
Brake piston removal Lucas SV Talk, Tuning & Tweaking 59 19-11-09 11:51 AM
Lunched Ford Ka Piston Alpinestarhero Photos 20 07-08-09 08:18 PM
Piston ring supplier mr_pils SV Talk, Tuning & Tweaking 3 26-02-09 08:02 AM
Leaking piston seal Tiger 55 SV Talk, Tuning & Tweaking 10 06-02-08 06:40 PM
