Old 02-03-10, 12:55 PM   #1
metalhead19
Default Clutch/gearbox issue?
I am having some issues with my clutch or gearbox and also the gear pedal. At the moment I am finding that when try to change down I have to release the clutch a small amount until I hear a click and then am
able to down shift.
This morning I also had the problem of the gear pedal not returning to it's resting place, I wud change up or down and it would stay there.
Any ideas on the problems?
Dan
Old 02-03-10, 12:58 PM   #2
fastdruid
fastdruid's Avatar
Default Re: Clutch/gearbox issue?
Typical problem is the lever pivot needs cleaning and lubing. Try that first and see if it makes a difference.
Druid
Old 02-03-10, 02:07 PM   #3
SUPERSTARDJ01
I have the same problem with the ZX and was told to do the same.
Old 02-03-10, 04:04 PM   #4
metalhead19
Ok thanks. Will give that a go
Gearbox Richie Stuff Wanted 0 09-07-07 08:09 PM
Gearbox Fix? seandixie SV Talk, Tuning & Tweaking 11 29-06-07 09:32 AM
gearbox Noise markmoto SV Talk, Tuning & Tweaking 19 03-07-06 02:37 AM
Gearbox problem??? shortie SV Talk, Tuning & Tweaking 1 14-05-06 02:20 PM
Gearbox Daglad SV Talk, Tuning & Tweaking 12 02-04-06 09:26 PM
