Old 08-03-10, 06:07 PM   #1
richiekuk
Default Cam swap
Hey all. I've done alot of reading about swapping the curvy inlet cam for a pointy one, and using the curvy inlet as exhaust.
As this seems a nice and thrifty mod (we like), I am maybe planning on doing this. But thought I'd ask the seasoned vet's about post swap performance, (if you'll endulge me)
Am I right in thinking that I may gain a bit of top end?
And does this top end gain, result in any low/mid range loss? (I do love the low down torque).
Thanks in Advance
Richie K
Old 08-03-10, 06:15 PM   #2
Default Re: Cam swap
I've got JHS cams fitted which are supposedly a bit peakier still and it doesn't feel any weaker than standard at the bottom.
Old 09-03-10, 04:26 AM   #3
tstruyk
and Ive got a set of JHS cams I may be looking to unload...
Old 09-03-10, 10:42 AM   #4
sv650racing
iv got some pointy spares inlet and outlet cams with sprockets and carriers
pm me if interested
Old 09-03-10, 11:46 AM   #5
richiekuk
Would changing the cams to "hotter" ones mean I would have to check valve clearances more often?
Richie K
Old 09-03-10, 12:36 PM   #6
sv650racing
No, just checking them when you put the new ones in!
Old 09-03-10, 02:52 PM   #7
Richie K
I've been checking mine every other oil change (so every 7k miles) just to be on the safe side but they don't seem to need it.
Your results may differ.
Old 09-03-10, 04:24 PM   #8
richiekuk
I dont do that many miles, and its due its valve clearances checking in 1000 miles anyway. So no bother there then.
Richie K
Old 10-03-10, 12:41 PM   #9
johnnyrod
johnnyrod's Avatar
My 1999 curvy before changing the cams:
www.johnnyrod.co.uk/dyno2.gif
and after
www.johnnyrod.co.uk/dyno3.gif
All teh bottm and midrange is there, plus extra top end, no changes needed in the carbs. I read up on this a lot before I did it and everyone else said the same things as well. Well worth it, picks up again over 7000rpm and opens a few eyes on the track!
Old 10-03-10, 01:02 PM   #10
richiekuk
Johnnyrod, cheers for the dyno graphs.
I am definatley gonna get it done, once I get some pointy inlet cams.
Richie K
Anyone want to swap??? Binky Idle Banter 0 06-08-08 03:16 PM
Anyone want to swap with me... furrybean Idle Banter 20 02-02-07 01:57 PM
Cam swap for K2 suzsv650 SV Talk, Tuning & Tweaking 6 12-01-07 06:57 PM
SWAP!! Marshall Stuff Wanted 6 11-05-06 11:34 PM
oh to swap or not to swap that is the question.. DrPain Bikes - Talk & Issues 27 25-04-05 02:48 PM
