Old 16-03-10, 10:55 PM   #1
magical_mover
Default Clutch lever suggestion - achey hand?
Hi all
I am really suffering when riding at the moment...never had the problem with any of my other bikes, but I find my left hand really hurts/aches when riding the SV...everytime i pull the clutch in the muscles really start to hurt...Normally starts playing up after about a 15 mile ride onwards...
I think it may possibly due to being a girl i have smaller hands and so it is a bit more of a stretch, I have adjusted the lever slightly to try a different angle but it doesnt really help.
Any suggestions? I just need the lever to be closer to the bar so its less of a stretch. Are there any other levers out there that would be suitable (sorry if dumb question!!)
Old 17-03-10, 12:38 AM   #2
5hort5
Default Re: Clutch lever suggestion - achey hand!?
yep, an easy fix (well hopefully), loosen off both the clutch and brake levers and twist them down, say about 15 to 20 degrees on the bars. This way yours hands wont be at such an angle to your arms and they wont hurt as much. Watch out for the clearances with the fairings and cables but this makes a big difference. It was the first mod I did when I had a pointy a few years back and it works a treat.
5hort5 is offline   Reply With Quote
Old 17-03-10, 01:07 AM   #3
ophic
ophic's Avatar
If you have smaller hands its possible to adjust the clutch so that the biting point is nearer the handlebar. This makes the stiff bit easier, as you have more strength the more your fingers are curled. It's a fine line though as you have to make sure the clutch isn't dragging.
Silver SV650SK3, Fuel exhaust
Old 17-03-10, 01:44 AM   #4
barwel1992
i have very small hands and dont have a problem at all so i think its somthing to do with the position of the leaver, adjust it but take the spaner with you go for a long ride and test out the positions untill you get one that is comfotable
Old 17-03-10, 10:37 AM   #5
ophic
ophic's Avatar
Perhaps, for a guy. But Miss Ophic has small hands for a girl. We struggle to find bike gloves that fit. Hence most clutch levers need various amounts of tweaking before she can ride it. Pulling away is the worst bit, as she can reach the lever, but has no control or grip when her fingers are mostly extended.
If you adjust it too far, you can't find neutral.
Old 17-03-10, 12:07 PM   #6
johnnyrod
johnnyrod's Avatar
Default Re: Clutch lever suggestion - achey hand?
5hort5 is right, tilting the lever down a little can make a big difference
Old 17-03-10, 12:13 PM   #7
barwel1992
i have woman size hands, lol my mum has longer fingers than me
Old 17-03-10, 12:21 PM   #8
ridelikeaturtle
Powerball.
http://www.amazon.co.uk/Powerball-Ne...rd_i=powerball
Old 18-03-10, 01:14 AM   #9
barwel1992
^ they are so adictive lol
Old 18-03-10, 12:23 PM   #10
phi-dan
phi-dan's Avatar
Would bending the lever (after suitable application of heat) be a workable idea?
If this is completely wrong and/or dangerous, then mods please delete or edit with "FFS NO!" or some such!
Was: Red curvy S: crash bungs, double bubble screen, fenda extenda, HEL front lines, OEM belly pan
Now: Blue FZ6 Fazer
phi-dan is offline   Reply With Quote
Gear Selection Lever and Clutch Lever for K3 SV650S xXBADGERXx Stuff Wanted 7 17-01-09 02:04 PM
K5 Pointy 650S right hand wing mirror, gear lever and clutch Bayside GTR Stuff Wanted 5 23-11-07 11:54 AM
K5 Pointy 650S right hand wing mirror, gear lever and clutch lever. Bayside GTR Stuff Wanted 0 29-10-07 11:24 PM
2 left indicators + clutch lever + gear lever for pointy k6 enduroman Stuff Wanted 3 06-09-07 09:26 PM
clutch lever and front brake lever Quiff Wichard For Sale - SV's and SV related items 4 19-03-07 12:05 AM
