Old 27-03-10, 08:12 PM   #1
P-J
Default Speedo and tacho not working.
.....My speedo and rev counter have stopped working? Also no display for mileage etc.
All lights are lit and everything electrical seems to be working ok bar these! T'was fine all day on the Cold warrior ride-out and then suddenly stopped working coming back into Bristol from Chepstow!
Any ideas anyone?
Before it is stated my RR was changed about 2 months ago brand new
Cheers PJ
Old 27-03-10, 08:24 PM   #2
Alpinestarhero
Default Re: Can anyone explain why....
CHeck the fuses first under the riders seat It may also be the big old connector block behind the dash itself, in which case you'l have to get those fairings off they can be prone to dampness and corrosion
Old 27-03-10, 08:33 PM   #3
_Stretchie_
Large Member
_Stretchie_'s Avatar
Because you're parked up and the engine is on...
Those potholes around Monmouth have probably knocked out all the cables
How to amuze an idiot:
Look right-> <-Look Left
Old 28-03-10, 01:53 PM   #4
P-J
Default Re: Speedo and tacho not working.
Right totally pee'ed off now
Stripped fairing off, checked all wires, checked fuses and EVERYTHING electrical works bar the rev counter, speedo and digital dash showing mileage!!!!!
Please anybody with any other ideas before I waste another day on this!!!
PJ
pinty combination meter(tacho, speedo) andreibax Stuff Wanted 11 02-06-09 10:10 AM
Speedo & Tacho Dying Normski SV Talk, Tuning & Tweaking 5 23-07-08 11:15 AM
Erratic speedo and tacho, engine very hot. chakraist SV Talk, Tuning & Tweaking 2 17-07-08 03:19 PM
sv650s curvy- what are the light bulbs behind the speedo/tacho? vzzzbuxt SV Talk, Tuning & Tweaking 2 19-09-07 04:48 PM
Tacho not working Tris SV Talk, Tuning & Tweaking 6 13-05-06 05:18 PM
