Old 03-04-10, 08:34 PM   #1
Stu
Trinity
Stu's Avatar
Default Can't write to a micro SD card
I've had an old micro SD card knocking about the house, not sure where it came from or if I've ever used it.
Tried it in my Sansa Clip+ Mp3 player but I can't add anything to it. I've tried formatting it, but still no luck.
Any help appreciated thanks
Old 03-04-10, 08:51 PM   #2
Richie
fantabulas
Richie's Avatar
Default Re: Can't write to a micro SD card
it's fubar....
My Flickr photos
Old 03-04-10, 08:56 PM   #3
Stu
Trinity
Stu's Avatar
Surely not
Old 03-04-10, 09:01 PM   #4
They're cheaper than chips anyway. Especially if it's an old one
Old 03-04-10, 09:21 PM   #5
Stu
Trinity
Stu's Avatar
ok, so recommendations where to buy & what size to get? I guess the bigger you get has economies of scale then it starts getting ridiculously expensive for the higher capacity. The player accepts up to 16GB (it has 2Gb internal) I was thinking 4 or 8
Old 03-04-10, 09:26 PM   #6
I always get the max the device can handle but it's up to you. I just got a 8gb off amazon for about £15
Old 03-04-10, 09:29 PM   #7
RobH13
7dayshop or mymemory have used both, but only ever buy sandisk cards, not the cheapest, but never had a problem.
Rob.
Old 03-04-10, 09:36 PM   #8
Stu
Trinity
Stu's Avatar
The player was only £26. Can't find a 16 for less than £30 odd.
I fancy 3x 4GB for £10, http://www.mymemory.co.uk/Micro-SDHC...Card---Class-6 but it's out of stock. It was an offer, so does that mean it won't be repeated?
Old 03-04-10, 09:39 PM   #9
http://www.amazon.co.uk/SanDisk-SDSD...0330793&sr=8-3
http://www.amazon.co.uk/SanDisk-SDSD...0330793&sr=8-1
Old 03-04-10, 09:49 PM   #10
boot
I've had them in a similar state before, and it can sometimes depend on the device you're using to format them with.
Option 1.
Try to format it in a camera.
Option 2.
Place card in card slot on PC (if you have one), alternatively this will probably work with usb drive too.
1. Start > Run > cmd
2. Type DISKPART
3. Type LIST DISK
identify the faulty disk. Disks will be listed with total sizes of disks, so make sure you get the right one - don't want to go formatting your hard drive .
4. Type SELECT DISK x (where x is the appropriate disk number from step 3.)
5. Type CLEAN ALL
6. Type CREATE PRIMARY PARTITION
7. Type SELECT PARTITION 1
8. Type ACTIVE
9. Type FORMAT FS=FAT32
10. Type ASSIGN
11. Type EXIT
If that doesn't work, then yes, it probably is fubar.
Motrax Indyspacer & Micro Arrows TSM Bikes - Talk & Issues 10 26-03-11 02:28 PM
Micro Men - A history of geekdom fizzwheel Idle Banter 28 15-10-09 11:17 PM
Oxford Micro Indicators Nitzer SV Talk, Tuning & Tweaking 6 27-05-09 09:22 PM
Mini / Micro Indicators Jdawg For Sale - SV's and SV related items 12 18-07-08 05:37 PM
Sd card 128 MB and card reader Quiff Wichard Idle Banter 15 15-06-06 09:17 AM
