Old 06-04-10, 08:57 AM   #1
muzikill
muzikill's Avatar
Default Best paddock stands?
As it says . . . I have done a search on e bay and do not want to buy cheap tat . . I have a abba bike stand already . . Need them for a engine drop and any other work in the future
Old 06-04-10, 08:59 AM   #2
Default Re: Best paddock stands?
You can remove engine on abba stand
Old 06-04-10, 03:53 PM   #3
sunshine
i just changed the rear sprocket on mine using nothing more than a jack and side stand, you can drop an engine out if its only on the side stand its not to difficult really.
Old 06-04-10, 03:55 PM   #4
+1 for ABBA stands
Old 06-04-10, 03:57 PM   #5
RobH13
Another Vote for the Abba Stand.
Rob.
Old 06-04-10, 04:06 PM   #6
If you're already got an ABBA stand, then you don't really need much else, unless you buy a front paddock stand.
I've got one and it lifts the front wheel off by lifting the headstock. But i don't really have the need for it.
Old 06-04-10, 08:32 PM   #7
mjc
if you want a paddock stand the motrax one im using at the moment is sturdy as you like and shouldnt be too pricey. works best with swingarm bobbins.
Old 07-04-10, 12:18 AM   #8
Lozzo
I have tried all sorts of paddock stands, and my favourite ones are made by Champion. They don't look like much, being made of small diameter tubing, but they are extremely easy to use and don't flex or bend like the Micron or MotoGP ones do. The best thing about the rear stand is the removeable handle, which means the stand sits right under the rear wheel and you don't clout it as you walk round - it also means I can stick the bike on the paddock stand in the race van alongside Danny's bike and close the door easily.
I bought mine from A+R Racing in Somerset via ebay.
Paddock stands keith h Hardware 5 15-11-09 03:40 PM
Paddock stands davidimurray Ancillaries 53 22-12-07 05:27 PM
Paddock Stands Lee Rainbow SV Talk, Tuning & Tweaking 22 09-08-05 11:32 AM
Paddock Stands rob13 Bikes - Talk & Issues 5 04-07-05 07:57 PM
paddock stands Quiff Wichard SV Talk, Tuning & Tweaking 15 27-10-04 07:24 PM
