Old 19-04-10, 12:39 PM   #1
James SV
Default cant source paddock fork adapters
Hi, im needing to get my front wheel on the paddock stand, I do own a paddock stand however its the type that has pins that would insert into a hollow spindle. (e.g r6)
Where can i get the fork type adapters to go fit to my paddock stand?
I have found the hook type, but i don't have bobbins, to put bobbins on my forks would i have to drill+ tap some holes as there are none on there!?
Cheers,
James
Old 20-04-10, 08:23 AM   #2
muffles
Default Re: cant source paddock fork adapters
What make of front stand is it? I think whether you can get the adaptors would depend on that. I have an Oxford front stand that goes under the fork, it would work with any fork - think that's what you're after.
Btw for the front bobbins, I thought they screwed into the front spindle somehow? I can't imagine you'd have to drill/tap holes in your forks
Old 20-04-10, 10:18 AM   #3
James SV
Hi, I'm not sure what the make of it is as it was given to me by a retired biker, so i may have to ivest in one of those!
As for the bobbins - there are holes higher up (one of which i have my tax disc holder attached to) but i would assume these are too high up to get enough lift :s
cant be screwed into the spindle though as its basically just a long screwed allen bolt.
Old 20-04-10, 11:40 AM   #4
muffles
Looking on the R&G web site it seems like they might supply a replacement spindle as part of the package. However they don't list fork protectors for the 650 (they had some for the 1000) so I assume that route is out...sounds like your best bet is a new paddock stand!
Anyone know where I can source a CB500 rad? Baph Bikes - Talk & Issues 3 04-07-08 08:25 PM
Finally tracked one of the buggers down - valve adapters! Al_Sweetman Idle Banter 6 15-05-08 09:55 PM
brake caliper adapters vl650 Stuff Wanted 1 08-02-07 05:49 PM
highspeedassault GSX-R->SV caliper adapters weazelz Stuff Wanted 0 15-11-06 08:33 PM
Recommend source forZ6's and fork modifications near Reading steve mac SV Talk, Tuning & Tweaking 7 28-04-05 06:57 PM
