Old 21-04-10, 06:39 PM   #1
SAMMY650
Default Valve clearances = New Gasket?
Just a quick question.....I'm about to check the valve clearances on my k6 sv650s, will i need to replace the cylinder head gasket or can i just use the old one is its not damaged???
thanks
Old 21-04-10, 07:02 PM   #2
SAMMY650
Default Re: Valve clearances = New Gasket?
Also, will i have to remove the radiator or can the clearances be checked without removing the rad?
Old 21-04-10, 07:04 PM   #3
BBadger
Rad must come off to get to the front im afraid.
But no, no gaskets involved just the cyclender head cover i believe.
Some one with more knowledge will be along soon though.
Old 21-04-10, 07:05 PM   #4
Rocker cover gasket is silcon rubber, so won't need replacing
Old 21-04-10, 07:13 PM   #5
BBadger
Nope....actually was at spannermans today while he was doing this.
Take off and clean all surfaces well and then i believe you re-grease slap back on and tighten everything back up.
[Edit]
Again dont take my word on the putting back together bit may need somthing else than rubber grease =s
Old 21-04-10, 07:14 PM   #6
NedSVS
The cam cover has a rubber gasket which you can re-use so long as you don't damage it, I bought new (not cheap) but could have saved my money. Old or new, apply a little sealant where the half round sections fit in the head. I did not remove the rad completely, I may have tilted it forward; some time ago now and I don't have the best memory, but I think I removed the airbox and got some access from above. Hope this helps.
Old 21-04-10, 07:14 PM   #7
SAMMY650
Cheers for the info guys
Old 21-04-10, 07:16 PM   #8
BBadger
TBH taking it off and replacing the coolant unless you did it recently cant hurt though and makes things less fidderly.
Old 22-04-10, 05:57 AM   #9
Spanner Man
[Edit]
Not grease young fella. A little silicone sealant around the cut outs. (These are the half moon shaped things).
Make sure you clean all the old sealant from the cylinder head, & the gasket itself before replacing the cover, or it'll probably leak.
If the gasket comes away from the cylinder head cover, hold it in place with a few drops of Superglue on the outside edge only.
Cheers.
Spanner Man
Old 22-04-10, 08:32 AM   #10
BBadger
What he said ^^
Valve Clearances stratman_001 SV Talk, Tuning & Tweaking 2 09-03-10 01:13 PM
Valve clearances - how do you know? SUPERSTARDJ01 Bikes - Talk & Issues 19 09-05-09 05:16 PM
Valve Clearances DanAbnormal Bikes - Talk & Issues 31 07-02-08 06:22 PM
Doing the valve clearances... instigator SV Talk, Tuning & Tweaking 7 16-10-06 10:08 PM
Valve Clearances HELP TSM SV Talk, Tuning & Tweaking 25 05-04-06 09:58 AM
