Old 28-04-10, 01:50 AM   #1
davepreston
Question factory suspension settings for your bikes please
right ive been learning about suspension set up from the master of the dark arts elmer fud
so now need the orgs help to get info on other bikes factory settings, you can get this info from your handbooks or from other forums you are members of,
these are the setting that the bike came with out of the showroom ,not what you recomend or just happened to be on your secondhand bike
eg sv1000 front preload 1 1/2 turns from full, rear preload 1 3/4 from full
so on and so forth please include rebound ,preload and compression
im looking for as many as possible so whichever bikes you have (i know some dont have all the adjustments above) please list below cheers
dave
ps if you could put the source as well that would be great
Old 28-04-10, 02:08 AM   #2
BanannaMan
BanannaMan's Avatar
Default Re: factory suspension settings for your bikes please
You'll be learning all bikes (jap anyway) come set up too softly sprung from the factory unless you weigh 11 stones or less.
Stock settings are merely a starting point.
Not what you asked for but here is a table of suggested susp. settings from SportRider magazine.:
http://www.sportrider.com/suspension...ngs/index.html
Keep in mind this too is only a starting point. Riding preference and style are also factors here.
Stock settings are carp for most when the bike is new.
If that bike now has 10k or more on the clock, they are useless.
...Bill
Old 28-04-10, 04:21 AM   #3
davepreston
i intend to start from factory settings the adjust from there, it makes it easier to have that as the base line , after that its down to setting the bike up for the particular rider
Old 28-04-10, 05:07 AM   #4
BanannaMan
BanannaMan's Avatar
Oops...
Forgive my derail Dave.
I thought you were seeking clues as to how to set up your own bike.
Will leave you with this one general tip:
If the fork springs have 10k or more on them (stock or replaced) you'll find cranked down somewhere between 2/3 to 3/4 of their adjustment on the preload to be the spot. Stock is usually 1/2 or less.
Back to the needed info then...
...Bill
Old 28-04-10, 11:48 AM   #5
davepreston
no worries mate, elmer set mine up for me and its fecking amazing ,so now im learning how to do it myself, any knowledge you have of the subject is welcome
hopefully i can get a list together of standard setting together for me to set up others bikes
Old 28-04-10, 02:49 PM   #6
AndyBrad
DAVE HAVE A LOOK AT THIS.
http://www.moto-racing.co.uk/Guides/...nsionSetup.htm
IM STILL STRUGGLING WITH MINE. GOT THE SAG SET RIGHT APPARENTLY BUT THIS REBOUND AND COMPRESSION MULLARKY IS NOT WORKING HOW I WOULD EXPECT. FOR SOME REASON I FIND MYSELF DROPPING THE BIKE IN TWICE. LIKE OK IM TURNING NOW THEN EITHER WOA!I NEED TO CORRECT BECAUSE IM TURNING TOO FAST OR SLOW. ON THE CORNERS WHERE IT DOES WORK ITS FANTASIC BUT THEN YOU GET THE OFF ONE (NORMALLY FST SWEEPING) WHERE IT JUST DOESNT FEEL STABLE. ANY IDEAS?
Old 28-04-10, 02:49 PM   #7
AndyBrad
C0ck!
Old 28-04-10, 06:17 PM   #8
Mr Speirs
Mr Speirs's Avatar
Ducati 749S Biposto
Front Suspension
Preload: 20mm
Compression: 8 clicks out from full stiff (16 clicks total adjustability)
Rebound: 8 Clicks out from full slow (16 clicks total adjustability)
Rear Suspension:
Preload: ?? Cant remember
Compression: 1 turn out from full stiff
Rebound: 1 1/2 turns out from full slow
Old 28-04-10, 07:22 PM   #9
Bri w
Bri w's Avatar
Honda VFR 800 A-6 with ABS
Front:
Spring preload Standard Position: Turn the adjusters until the 2nd groove from the top aligns with the top surface of the fork caps.
Rear suspension:
Rebound damping: Turn fully clockwise till it stops(hard on). Turn 1/4 anticlockwise till two punchmarks line up.
Spring preload: Has 35 adjustment marks. Turn fully anti clockwise (soft setting). Turn 7 clicks clockwise for standard setting.
Old 28-04-10, 10:14 PM   #10
Originally Posted by BanannaMan View Post
Oops...
How can you say that when the setting includes internal preload as well as the adjuster
suspension settings? AndyBrad Bikes - Talk & Issues 8 08-03-10 03:29 PM
SV1000 - Standard Factory Settings Jay-ninja SV Talk, Tuning & Tweaking 8 24-09-09 08:35 AM
factory settings. Gene genie SV Talk, Tuning & Tweaking 3 15-11-08 03:44 PM
Suspension settings? thor SV Talk, Tuning & Tweaking 3 18-04-05 08:45 AM
Suspension Settings The Polarbear SV Talk, Tuning & Tweaking 6 12-01-05 08:34 PM
