Old 28-04-10, 04:52 PM   #1
Paul the 6th
Paul the 6th's Avatar
Default bleeding 6 pot tokico's
2 hours I've been soaking my hands in brake fluid & still the brake lever is coming to within an inch of the bar/air is teasing me by coming out in hundreds of bubbles & then none at all for 5 minutes...
I've had the calipers to bits, pistons out & cleaned, new fluid & dust seals, new rings between the caliper halves, everything tightened up as per manual torque settings, fitted back on the bike, banjo's tightended up to correct torque...
I've got a bit of clear tubing over the bleed nipples so I can see the fluid & air bubbles coming out. Every so often the bubbles stop appearing in the fluid so I nip the bleed nipples finger tight, pump the lever quickly a few times & it gains a bit of back pressure. If i then let go and pull it once, it's back to being rubbish again.
Am I doing something wrong?
Old 28-04-10, 04:58 PM   #2
Wideboy
Evel Knievel
Wideboy's Avatar
Default Re: bleeding 6 pot tokico's
are they braided lines? or standard with a Y in the middle?
if they have a Y and your bleeding individually start with the one furthest away from the handle.
when i done the gsxr front end it took me about an hour to pump it through
also depends on what bleeder you have, i find the automatic ones that circulate back to the top are quicker
edit: oh and before you nip up the nipples pump the leaver and hold it in whilst you tighten the nipple
05 DRZ400E
RIP hovis
Old 28-04-10, 04:59 PM   #3
Paul the 6th
It's standard lines with one line going to offside caliper, then from offside over the mudguard to nearside. Started with nearside, then swapped to offside, then back to nearside, then back on offside and about to go back to nearside...
I've used nearly a litre of brake fluid and lever is still no where near = that CANNOT be right..
Old 28-04-10, 05:00 PM   #4
Wideboy
Evel Knievel
Wideboy's Avatar
you sure you aint just ****ed them up?
05 DRZ400E
RIP hovis
Old 28-04-10, 05:09 PM   #5
Paul the 6th
oh yeah i almost forgot to tell ya gav, f*** off
Old 28-04-10, 05:14 PM   #6
barwel1992
bolt the bleed nipples up and sit on the bike with rez cap off, hold the leaver in and shake the bike, then when no more bubbles appear in the rez, try and re-bleed, if loads of bubbles are still coming through the tube then you more than likley leaking air in some where
literally took me 15 min to do my brakes on the sv this way but had braided hoses
Old 28-04-10, 05:20 PM   #7
Paul the 6th
yeah I've been waiting on YC to sort out braided lines...
Already tapped the calipers with a wooden mallet as suggests by a few guys on gixerjunkies.
Been at it for nearly 3 hours now, gonna stick it in the garage for the night with lever tied back.
If i don't murder anyone with pure rage in the meantime, I'll report back tomorrow...
Old 28-04-10, 05:31 PM   #8
BBadger
Read your post on JG...i think giving the bike a shake/ tilt might help as there could be bubbles stuck in the top banjo just after the mc which might not be shifting ??
Old 28-04-10, 05:35 PM   #9
Paul the 6th
ironically enough I've bought a brembo master cylinder off a guy on GJ - it's got a bleed nipple on it but the stock one doesn't grrrr
Will drop bike off paddock stand and give it a shot before packing up for the night and getting p*ssed
Old 28-04-10, 05:35 PM   #10
Dave20046
Dave20046's Avatar
Is there a bike between the reservoir and the mastercylinder? If so you'll need to squeeze that bike every so often. Worth leaning the bike over so the masterclinder is the highest point and giving a go like that for a bit, also tap your lines. Make sure all the banjos are torqued up.
Squeeze open/close release etc.
Speed Bleeding! Rich Bikes - Talk & Issues 11 20-04-08 02:01 AM
Brake bleeding kit? gstrong82183 SV Talk, Tuning & Tweaking 38 28-03-08 10:07 PM
bleeding thing Taylor1975 SV Talk, Tuning & Tweaking 8 17-03-08 10:14 AM
Bleeding Brakes - Again HopefullySoon SV Talk, Tuning & Tweaking 2 28-08-07 09:13 AM
Bleeding Brakes (Bleeding Kits) 21QUEST SV Talk, Tuning & Tweaking 8 20-06-06 05:31 PM
