Old 07-05-10, 03:40 PM   #1
Longway
Default Faulty K3 Speedo
Whilst out on my SV650 K3 today my speedo suddenly started misreading jumping up and down giving much slower readings than I was actually doing. My first thoughts are faulty speedo sensor on the wheel, can anyone confirm my suspicions?
Old 07-05-10, 05:07 PM   #2
barwel1992
Default Re: Faulty K3 Speedo
most likley be the rotor, mine did what yours is doing when it broke
Old 07-05-10, 05:17 PM   #3
mcireland
Yup probly the yoke down at the wheel, one or more of the bits has broken off. Happened to me twice so far
Old 07-05-10, 05:18 PM   #4
barwel1992
Originally Posted by mcireland View Post
Yup probly the yoke
yoke ??? its the speedo rotor
the yokes hold the forks and stem
Old 07-05-10, 05:25 PM   #5
Jayneflakes
Jayneflakes's Avatar
Most likely it is the stupidly soft, made of plastercine, magnet on the wheel. If the tabs have dropped off, it wont spin right. Fix or replace and that should get you speeding appropriately.
Jayne you're a Pussy Magnet
Old 07-05-10, 05:35 PM   #6
mcireland
Ah yes apologies, you dont use that word to describe everything and anything do ye unfortunate naming convention in this case
Old 08-05-10, 04:46 AM   #7
Longway
Thanks for the replies, I will remove it and see if it can be repaired, don't fancy buying a complete new sensor at the moment, just had to pay out on new back tyre on due to a puncture
Old 08-05-10, 05:49 AM   #8
Longway
Just dropped wheel and removed sensor and all is now clear to me, as you say its the rotor, all 4 lugs lugs have broken off, I will call the main dealers later and see if they have one in
Old 08-05-10, 05:53 AM   #9
Jayneflakes
If you can find the lugs, just glue them back on. I used a spot of Araldite and it worked fine again.
Old 08-05-10, 07:01 AM   #10
Longway
It just so happens I have got some Araldite, I'll give that a go, nothing to loose by trying
Faulty indicator flymo SV Talk, Tuning & Tweaking 10 22-04-08 09:06 PM
My SV650S seems faulty … Blue_SV650S SV Talk, Tuning & Tweaking 13 11-03-06 12:32 AM
Faulty/erratic speedo reading SV1000 ginger SV Talk, Tuning & Tweaking 5 03-05-05 10:05 AM
faulty speedo ? dangerous bri SV Talk, Tuning & Tweaking 4 21-03-05 03:10 AM
