Old 26-05-10, 02:15 PM   #1
barwel1992
Default neutral light does not work
Ok so neutral light does not work on the new dash (vapor dash) , the indicator lights work and all the other lights work on the dash like normal apart from the neutral light, i have checked the wiring from the clocks to the relay and no visible snags and it passes current using a multi meter so its not that bit of wiring.
it could be one of 3 things that has gone wrong, the flasher relay (as its called) might have blow even if the indicators still work (happen'd to some one on svrider site he grounded the wire by accident) the wire from the gear position sensor to the relay or the gear position sensor it's self
has any one had a problem like this before ? and what do people thing the most likley cause is ?
Old 26-05-10, 02:18 PM   #2
Lozzo
Default Re: neutral light does not work
It's in gear
Old 26-05-10, 02:22 PM   #3
badsaboy
what about the bulb in the neutral light??????
Old 26-05-10, 02:24 PM   #4
barwel1992
It's in gear
nope
thats fine as well
ohh and to add when the bike is on and in neutral my multi meter does not pick up any voltage from the neutral wire (grounded to ground wire)
Old 26-05-10, 02:29 PM   #5
badsaboy
why not try reconnect the old neutral light and see if that works. if it dosnt then it must be the sensor!!!!
by the way im a noob so might be totally off the ball!!!!!
Old 26-05-10, 02:35 PM   #6
barwel1992
i could if they weren't in pieces (smashed in my off) and i think your along the right lines, and im pretty much coming to the conclusion that its the relay/diode
Old 26-05-10, 02:35 PM   #7
Lozzo
No, it's a good suggestion. Wire in a simple bulb on a couple of leads and connect them up to see if it is the neutral switch. Just remember that the neutral switch is in the live feed, there is always power down the cable going into it, and the switch earths out when in neutral to make a connection and bring the light on.
Old 26-05-10, 02:36 PM   #8
You need 2 threads on same problem?
What happens when you ground wire to light?
I would just bypass relay as matter of course before it c*cks up.
Old 26-05-10, 02:41 PM   #9
Lozzo
Why are you running the neutral light wiring through the indicator relay?
Old 26-05-10, 02:42 PM   #10
barwel1992
tried with a new bulb and got nothing
the other thread was more about the indicator lights and this thread name will get more views than the trail tech vapor help.
and you mean the same as Lozzo ?
and will do that in a bit see what happens
Neutral Light for curvy ricky_t Bikes - Talk & Issues 0 15-03-10 03:38 AM
Neutral Light DarrenSV650S Bikes - Talk & Issues 3 09-05-09 05:12 PM
Me being a numpty - no neutral light and fi light is on Whitehouse SV Talk, Tuning & Tweaking 8 03-04-09 03:50 PM
Intermittent Neutral Light mikebrooman SV Talk, Tuning & Tweaking 2 19-02-09 03:28 PM
Neutral Indication Light? MitchC SV Talk, Tuning & Tweaking 6 01-04-05 08:15 PM
