Hello all !!!
I've been in biking a few years now (but only on L Plates), it is part of my plan to get full licence within the next few months !! there has been a lot of thinking of what i would like my first big bike to be !!I have decided that i would like an SV, most possibly will be the curvy one (or if i'm correct the K1). kinda chose it as my brother has a VTR 1000 and i really love the v twin sound track.I have read a lot about SV's and i know a few common faults are forks lowers tarnishing and old shocks both end and not to buy a raced one. I know from the research done on my brothers bike that most bike have common faults, was wondering whether there are any common faults on SV's Thanks a lot for any advice!! |
Wiring, the loom can be fouled and chaffed by the seat screws causing shorting and very strange running.
Fuel tank drain corrodes if blocked, causes a fuel leak.
Not Grumpy, opinionated. |
The stock suspension is crap
The suspension is not that bad, the standard bolts used rot out a bit and some of the more hidden parts need stripping and cleaning occasionally, but not a lot really.
Things gone a bit wrong on my one so far have been the clutch worm gear and a fault with the alarm. However the alarm was due to the pillock who fitted it and the clutch was due the the current owner not bothering to check it. ![]() |
Japanese handling and Italian electrics
Mine seems to shake things off too, although Nyloc nuts and threadlock seem to have stopped that - although it managed to shake its gearlever out last night - god knows how! |
The pilots.
#7 | |
A trip to pro-bolt can sort the rot! The brakes do need cleaning from time to time. Invest in a good set of sockets and ring spanners. A bottle of FS365 or acf50 does not go amiss and coat the engine and chasis and suspension
Lack of grease in... errrr... everything!
#9 |
Rectifier-regulator.
#10 |
-bad paintwork on forks
-internal tank corrosion caused by overflow -weak supsension front and rear for fat ppl -crap dragging clutch plates -bad regulator -chaffing loom -speedo rotor -seizing caliper pins -oil pickup at front (dont wheelie) -rear underframe corrosion |
Exhausts & Common faults | Knightwing | SV Talk, Tuning & Tweaking | 16 | 23-10-08 08:39 AM |
Gearbox jamming... anyone know of faults on a SV650s | paulsemale | SV Talk, Tuning & Tweaking | 8 | 19-05-08 12:23 PM |
RIP Common Sense | kd sweety | Idle Banter | 1 | 29-03-08 09:42 PM |
The common cold | DanDare | Idle Banter | 10 | 22-02-08 09:28 PM |
Possible reg/rec faults.Want to be sure - Got home OK! | andyb | SV Talk, Tuning & Tweaking | 28 | 16-11-06 03:12 PM |
