Old 27-05-10, 09:15 PM   #1
4130chris
Default Bike dropped all it's oil.
bike just spat it's oil all down the motorway, 3o mins waiting for tow-truck.
really wasn't expecting that...........
s'pose i'll try and take the engine out and from there see if it's easiest to source an engine or fix mine.
well, we'll see....
Old 27-05-10, 09:27 PM   #2
TSM
The Sick Man
TSM's Avatar
Default Re: Bike dropped all it's oil.
apart from loosing the sump bolt the only other ways for a SV engine to loose lots of oil is a broken oil rad pipe (if pointy) or aparently if the front sprocket bolt is loose it will spil oil too or then the obvious things like the clutch cover comming off or oil pressure switch braking off
Old 27-05-10, 09:28 PM   #3
4130chris
http://www.nooooooooooooooo.com/
Old 27-05-10, 09:34 PM   #4
4130chris
tsm -
thanks for the speedy reply
- not the sump plug - i had a quick look under whilst waiting on the 'hard shoulder'
-don't think it's the oil rad pipe (it is a pointy 2003)
- so tomorrow will investigate - front sprocket bolt (i've just adjusted the chain..) and oil pressure switch. Don't think the clutch cover has 'come off'
Old 27-05-10, 11:31 PM   #5
carternd
Originally Posted by 4130chris View Post
That's amaaaaaaaaaaaaaaaazing!
(im sad)
You'd notice if the clutch cover had come off. Like, a massive bit missing from the side of the engine!
Old 28-05-10, 10:16 AM   #6
4130chris
TSM - seems you were right!
loose sprocket bolt! so my next question - can i tighten the bolt , add oil and continue hoonage? - or have i destroyed some seal?
looking much better than yesterday (thought i needed a new engine!)
Old 28-05-10, 06:37 PM   #7
4130chris
suppose is should replace seal no-35 -
http://fiche.ronayers.com/Index.cfm/...ON_(MODEL_K3)_
any tips on removing the old one - just screwdriver the thing out? then just push tje new one in place? hope it's that easy!
p.s is there any chance of a leak from 15 - ?
http://fiche.ronayers.com/Index.cfm/.../Group/CLUTCH_
Old 28-05-10, 08:00 PM   #8
Try retorque it, if you are lucky you will not have blown engine.
Old 28-05-10, 08:04 PM   #9
4130chris
"blown engine"!
hope not!
plan is to order new seal and re-torque , then ride away
Old 28-05-10, 08:23 PM   #10
wyrdness
"blown engine"!
hope not!
You might want to put new oil in before you ride away
Dropped my bike. neilhatch SV Talk, Tuning & Tweaking 9 02-12-09 09:18 AM
Dropped Bike hol49 Bikes - Talk & Issues 12 25-07-08 05:15 PM
Dropped bike. cmc1 SV Talk, Tuning & Tweaking 5 19-06-08 10:22 AM
Dropped bike suzsv650 Bikes - Talk & Issues 2 02-08-07 03:16 PM
dropped me bike Quiff Wichard SV Talk, Tuning & Tweaking 26 16-04-07 10:05 AM
