Old 01-06-10, 05:37 AM   #1
mister c
mister c's Avatar
Default Didnt get out on the bike this weekend
Because I was messing with my FZR. What started out as a good idea ended up being a 6 hour job. It's done now & I just hope it helps handling.
Its a 2009 R6 Shock, fully adjustable. My mate made up the dog bones & spacers, but I had to fine tune some things.
Bottom of the shock needed to be ground down & rounded off for clearance
Top spacers were made .5mm too thick. I haven't got a vice at home, so had to sand them down....... 2 hours
Nice job on the Dogbones
Job Jobbed
Old 01-06-10, 08:56 AM   #2
Default Re: Didnt get out on the bike this weekend
Looks like a well finished shock.
Not meaning to give dem negative waves, but I don't like look of those dogbones, way you have radiused narrowing of section looks too far and sharp and will create stress riser. You want smooth radius so you don't get stress concentration.
P.S where is the ride height adjuster on that fully adjustable shock
Old 01-06-10, 09:06 AM   #3
mister c
mister c's Avatar
He He, I should change that then, nearly fully adjustable lol.
There is a guy in the States that has put up the engineering drawings for the bones & spacers, my mate copied them. they are made from 1/4" steel plate, so should be ok. I know I'm fat, but it should take my weight & I ride like a pussy, so there shouldnt be too much stress on them
Old 01-06-10, 09:09 AM   #4
Ok mate it's your ass, but they are under cyclic loading and there could be risk, albeit slim, of fatigue failure.
Riding like a pussy or not, dogbones do not care whether you are hitting a bump at 10mph or 110mph.
Old 01-06-10, 09:26 AM   #5
Lozzo
He's right Colin, this happpened at 45mph
Result was one broken ankle and a few more scrapes down the old Bandit 600 ratbike
Old 01-06-10, 10:53 AM   #6
mister c
mister c's Avatar
Got me worried now
Will have to have a word in my mates shell like & see if he will make me a couple more. Thanks guys The org, ever helpful once again
Old 01-06-10, 12:09 PM   #7
Lozzo
Make them as beefy as possible around the mounting bolts and have a smooth radius from the shank into the ends, yours look a little too square at each end which could cause a stress induced failure. Best of all would be completely parallel bars raduissed off at each end with the eye bolt holes machined in, if there's room for wider dogbones in the set-up, which it looks like there is on your bike. Some, like my old Bandit's, needed to have slimmer shanks to clear the swingarm, but yours don't.
Old 01-06-10, 01:07 PM   #8
mister c
mister c's Avatar
Spot on Lozzo. I was wondering why they had to be that shape. I have some bar here at work, so parallel it is then.
Many thanks
Old 01-06-10, 02:07 PM   #9
barwel1992
i agree i dont like the looks of them dog bones, like the shock though, what length is it ?
Old 01-06-10, 02:09 PM   #10
I think they are seriously short for SV.
What you want is davieSV to make you new end for an RSV sachs unit.
Well i didnt get stuck did you ?? hindle8907 Idle Banter 7 19-09-09 12:05 AM
Didnt even get to show her off :( stevo_sv Photos 23 08-11-08 08:22 PM
Didnt know where to post so... Coolblue 650 The Border Patrol 16 04-11-08 05:24 PM
Lesson didnt go too well :( magical_mover Bikes - Talk & Issues 49 06-09-07 09:25 AM
Why I didnt buy an SV... Redster Bikes - Talk & Issues 17 14-07-07 10:29 PM
