Old 07-06-10, 02:27 PM   #1
widget
Default Missing wormdrive bearings
My clutch had been dragging when pulled in and generally felt rough.
I stripped down the worm drive found aload of gritty grease and 4 missing ball bearings. This has now notched the guide aswell as afair bit of side to side play when put together.
Are the notches means to replace and where could i get this size bearing from as i have no way of measuring this correctly with a rule.
Old 07-06-10, 02:34 PM   #2
xXBADGERXx
Default Re: Missing wormdrive bearings
What model is it ?
Old 07-06-10, 02:48 PM   #3
barwel1992
took mine off the other day and they fell out all over the floor, bloody things. mine was also a mess so greased it back up and put it back on
you could always put a sv1000 hydrolic clutch on, using the sv1000 push rod cut down to 122mm will need to mod the sprocket cover though
Old 07-06-10, 03:22 PM   #4
widget
Its a k3 650
Old 07-06-10, 03:38 PM   #5
Biker Biggles
Biker Biggles's Avatar
When that happened to mine I just bought a new wormdrive from Suzuki.I dont think it was very dear.
Old 07-06-10, 07:08 PM   #6
The lifters wear and get notched quite early in their life, buy a new one - the clutch action will be much nicer.
Old 07-06-10, 07:29 PM   #7
xXBADGERXx
I have a backup one here , I`ll dig out the Micrometer and have a measure but as others have stated , sometimes it`s just worth buying a new one .
Old 07-06-10, 11:32 PM   #8
Lozzo
The worm drive is similar to a Bandit 600s. My Bandit one gave me trouble for about 6 months after numerous rebuilds and geasing with new bearings etc. In the end I fitted a new one - £26 - and it was perfect from then on.
I'd say don't bother rebuilding, just put a new unit in.
Old 07-06-10, 11:51 PM   #9
davepreston
we got the bearings from the pushbike department of halfords for free , clean regrease and put bearings back in, this was on beanies k3, afaik she's had no probs since
Bearings Wideboy Bikes - Talk & Issues 6 08-12-09 09:18 PM
bearings sv_rory SV Talk, Tuning & Tweaking 5 12-02-09 07:29 PM
What I'm missing for the AR... Gordon B 2008 Annual Rideout 19 01-07-08 01:00 PM
That missing something... Alpinestarhero Idle Banter 11 02-12-06 09:05 AM
missing my SV Wiltshire7 Photos 15 17-08-05 09:49 PM
