Old 21-06-10, 01:56 PM   #1
andreis
Default Starting prolem after changing 'bars.
Hi all!
Yet another curvy problem here...
I have recently done a bar mod by way of which I have replaced the clipons on my 650S ('00) with proper bars to get a better position..
It shortly developed a strange problem.. It wouldn't always try to fire up when I press the starter button. It seems that opening/closing the starter circuit (the red on/off button) and trying a couple of times eventualy gets the job done and it fires up on the first time it actually attempts to.
Seems like there would be a loose contact somewhere, but I can't seem to find it.
I have rechecked the contacts around the controls, but they all seem fine...
There is no blown fuse, as then it wouldn't try firing up at all.
How would I go about checking if the clutch sensor says that it's fine to fire up?
Any ideas in general?
Old 21-06-10, 08:41 PM   #2
Default Re: Starting issue
Clutch switch is the first place I'd look, as with anything that's been disturbed it's the obvious place to go back to, if you have a Curvy you can bypass the switch to obviate the problem - but don't forget the bike will now start in gear and lurch forward.
Dirty starter button contacts are not uncommon too.
Old 23-06-10, 01:36 PM   #3
Razor
Default Re: Starting prolem after changing 'bars.
Bridge the clutch switch to test if it's that. I usually just stick a bit of wire in the 2 female plugs.
SV650S bars for SV650 bars? MikeC SV Talk, Tuning & Tweaking 11 08-12-06 12:34 PM
Which bars? oldjack SV Talk, Tuning & Tweaking 3 03-08-06 07:15 PM
End bars....help rubbermonkey SV Talk, Tuning & Tweaking 8 08-02-06 07:57 PM
Has anyone tried 'Ace bars' OldBoy SV Talk, Tuning & Tweaking 2 01-06-05 08:22 AM
Tie bars jonacol SV Talk, Tuning & Tweaking 0 17-03-05 02:11 PM
