Old 30-06-10, 08:35 AM   #1
Dave Mac
Default Cut air filter, loss of power.
i have cut the centre out of my air filter (the hard plastic bit) and i have raised the front of the tank by about 3 mm.
however when i hit about 7000 revs im getting a loss of power. it still has the padding on the tank. i thought about removing it but it is stuck in fast and not loose so i cant see that being the problem especially as it didnt do it before i changed the filter
any ideas?
i am thinking of putting the old one back on now
its a 2002 curvy
cheers dave
Old 30-06-10, 08:47 AM   #2
jambo
jambo's Avatar
Default Re: Cut air filter, loss of power.
To clarify: You have a curvy (2002) SV650 and have widened the plastic entry hole in the centre of the air filter to make it more free flowing?
If this is the case, put the old one back in and see how you go. My suspicion is that the mixture may become leaner at high RPM as the carbs are not suited to the non-standard filter.
If the problem goes away with the old filter fitted you have your answer
Jambo
Old 30-06-10, 08:58 AM   #3
Dave Mac
cheers i had a feeling that might be it, thought i would post and see.
the extra 3 mil clearance at the front of the tank shouldnt matter should it?
Old 30-06-10, 09:00 AM   #4
jambo
jambo's Avatar
If in doubt, put everything back to standard and start from a known good place. However, of the two modifications, this should be the least significant.
Jambo
Old 30-06-10, 09:21 AM   #5
Dave Mac
cheers, im going to put the old filter in and give it a bash with the extra 3 mil clearance, if it still struggles ill keep the old filter and remove the 3 mil
many thanks
Old 30-06-10, 11:01 AM   #6
I'd say with a fair degree of confidence that it's running as lean as a starving crackhead through iceland.
Old 30-06-10, 11:04 AM   #7
demonicus
my fault! i gave him the filter to cut up as i put a k&n in mine.
Old 30-06-10, 11:05 AM   #8
can run alright like that, but you need to rejet.
Old 30-06-10, 11:08 AM   #9
demonicus
i recall something you said about 5 quids worth of mikuni jets would sort the problem, is that correct? what size did you mention?
Old 30-06-10, 11:08 AM   #10
demonicus
he just wants to be able to keep up with me!
Loss of power, now no go at all. jnr-biker SV Talk, Tuning & Tweaking 8 22-11-09 10:50 PM
sudden loss of power Ben Flanagan SV Talk, Tuning & Tweaking 11 22-04-08 12:59 PM
Power loss!! chris8886 Bikes - Talk & Issues 12 01-12-07 12:56 PM
Power loss? FreshAL SV Talk, Tuning & Tweaking 6 02-03-06 11:18 AM
Loss of power..... Nekkid SV Talk, Tuning & Tweaking 16 21-10-04 05:00 PM
