Old 04-07-10, 12:27 AM   #1
thulfi
Default My chain is goosed.
...dear oh dear.
YouTube Video
Not had my er6 long, but haven't checked it for a bit. I'm no chain expert, and the only 'pointers' I've been given is the quick run through by my instructor minutes before my mod2, but now this aint right surely.
I can even hear it clunking around half the time (I think) which led me to check it, as not luubed or cleaned it in a while. To be honest, it was pretty rusted before I bought the bike, I'm thinking perhaps time for a new chain.
Either way, not getting back on til I tighten it me thinks!
Old 04-07-10, 02:55 AM   #2
danf1234
Default Re: My chain...
Nooooooooooo far too slack. I would sort that ASAP before it jumps the sprocket and you end up proper fooked.
Old 04-07-10, 06:42 AM   #3
keith_d
keith_d's Avatar
I'm not a chain expert either, but here's my 2d worth.
1) Inspect both the sprockets. The teeth should be nice and symmetrical, if they're worn go to step 5.
2) Try to pull the chain away from rear sprocket at the 3 o'clock position. If it moves more than about 10mm go to step 5.
3) Clean and lube the chain then tension it correctly. Check it again in a hundred miles, if it has become slack again go to step 5.
4) Check and lube the chain regularly. Don't go to step 5 until it shows signs of wear.
5) Replace the chain and sprockets
Keith.
Old 04-07-10, 09:55 AM   #4
mjc
Originally Posted by keith_d View Post
Chain expert stuff
What he said. Lube your chain every couple of hundred miles or once a week, or when it looks like it needs it. I clean and check tension every 500 miles, which is probably excessive but works for me.
Old 04-07-10, 10:17 AM   #5
Thats about my sequence is
Old 04-07-10, 11:36 AM   #6
thulfi
Keith.
cheers mate, will do. That's very useful. Ive got some of those muc-off cleaner and lube but theyre awful. A bit of paraffin to clean it with and some good quality castrol lube?
Old 04-07-10, 11:40 AM   #7
hongman
Scottoiler and forget about it
Old 04-07-10, 01:00 PM   #8
mjc
get a 3 pack of tescos toothbrushes, the ones that have a flat handle. use one for cleaning your teeth. the other two, tape together with bristles facing inwards. use with paraffin to clean chain, then wipe off paraffin with a rag and reapply lube
Old 04-07-10, 02:33 PM   #9
hongman
Not a bad idea that, think I'll have to do the same!
Old 04-07-10, 05:12 PM   #10
Razor
i use wd40 to clean my chain, then once i've gone for a short blast spray on chain lube and leave to soak in...
i had a scottoiler on my curvy, but can't afford one for my pointy at the mo
Morax Gold Chain Wax / Wurth Chain Wax glade Ancillaries 3 14-02-08 06:41 PM
Is my tyre goosed?? Help!! Carrot Cruncher SV Talk, Tuning & Tweaking 51 22-05-07 12:47 PM
How can I tell if my rear shock is goosed? Razor SV Talk, Tuning & Tweaking 6 11-09-06 08:38 PM
is my battery goosed? jim@55 SV Talk, Tuning & Tweaking 0 16-05-06 12:50 PM
Will stiff chain link cause chain noise dclifford SV Talk, Tuning & Tweaking 8 16-08-05 11:56 AM
