Old 09-07-10, 05:05 PM   #1
hongman
Default Polishing forks - how?
Quick question...
Can I apply autosol + polishing drill bit directly to Curvy forks?
How well do they come up?
As mine look furred and has corrosion in some places I was going to give them a shine and ACF50 it.
Old 09-07-10, 05:30 PM   #2
Default Re: Polishing forks
I used some Nitromors to strip any laquer off, but none came off, so I don't think there's much on there.
Yep, most of the fork polishes up real nice
Old 09-07-10, 05:35 PM   #3
Lissa
Just Ballast
Lissa's Avatar
This thread may help.
http://forums.sv650.org/showthread.p...ight=polishing
Old 09-07-10, 05:40 PM   #4
hongman
ooo shiny shiny
Old 09-07-10, 08:42 PM   #5
toby_smith
Originally Posted by hongman View Post
ooo shiny shiny
I just done mine. There was a few bits that didnt come up super good but I'm planning on taking the forks out and doing them properly over winter.
For some reason the left hand side was alot harder work but has come up alot nicer. The other side is going to require some even more elbow grease and maybe the wet and dry paper treatment.
I used solvo autsol and it did a cracking job.
No pics though sorry
Old 09-07-10, 09:01 PM   #6
Does anyone know if you can polish USD gold gixxer forks?
Old 09-07-10, 10:36 PM   #7
TamSV
TamSV's Avatar
What are you wanting to do? Clean them up or lose the gold altogether?
Old 09-07-10, 10:41 PM   #8
They're clean enough. I want them silver instead of gold
Old 09-07-10, 11:15 PM   #9
TamSV
TamSV's Avatar
I take it that's an anodised finish? You should be able to sand through it but I reckon it'll take a bloody long time. It's a lot tougher than paint.
Unless you fancy rigging up an acid bath?
Oven cleaner works if you're VERY careful and don't leave it on too long.
I've used it on very small parts before - never anything as big as forks. It involves some nasty chemical reactions so care is needed.
Now, you're starting to like that gold again aren't you?
Old 09-07-10, 11:18 PM   #10
Yeh it's anodised. I might give it a try over winter. Wonder if S Doc 100 would work
Polishing up the forks Mike2165 Bikes - Talk & Issues 6 01-03-09 09:58 PM
Front forks (polishing) suzsv650 SV Talk, Tuning & Tweaking 2 06-03-07 10:29 PM
polishing. kwak zzr SV Talk, Tuning & Tweaking 2 25-06-06 07:09 PM
Polishing alex.j SV Talk, Tuning & Tweaking 7 16-02-06 02:03 PM
Polishing pencil shavings SV Talk, Tuning & Tweaking 8 10-01-05 11:59 PM
