Old 21-07-10, 05:12 PM   #1
Default What if....
Just a hypothetical type thing.....
You're going along a twisty country road at a good pace. All of a sudden you find the road is covered in tiny gravel. Coming up is a tight bend.
Do you.....
Brake gently?
Only use the rear brake?
Change down?
Don't touch the brakes, just lean in and hope?
Go straight on, in to the field?
What do you do?
Old 21-07-10, 05:15 PM   #2
MR UKI (1)
Default Re: What if....
Do you.....
Brake gently?
Change down?
What do you do?
Sh!t myself
Old 21-07-10, 05:16 PM   #3
RichT
Personally I engine brake as much as I dare and lightly use the brakes to dump some speed (75/25% rear to front). Then if I feel I'm still too hot I get my body off the bike through the corner to keep it as upright as possible.
Old 21-07-10, 05:17 PM   #4
fizzwheel
fizzwheel's Avatar
Of course one would argue that you should be travelling at a decent enough speed to allow you to react to an on coming hazard such as the gravel you suggest in enough time to avoid it all together.
I've had it happen a couple of times, First time I slowed as much as I could dare and then rode through it on a neutral throttle trying to keep the bike balanced on the suspension.
Second time, I dragged the back brake and made it around the corner.
One thing I'd defo not do is panic and grab the front brake...
Old 21-07-10, 05:20 PM   #5
Sh*t yourself seems to be the primary course of action.
Spotting the gravel in good time is preferable.
Old 21-07-10, 05:21 PM   #6
MR UKI (1)
I remember seeing a response to a guy on another forum a while back who was complaining that he exited a blind bend on a country road to find a road closed barrier directly in front him. He said he exited the corner at 60mph+ and didn't have time to react and ended up going into the hedge. The response was the same as Fizz's, should he have been quite so quickly not knowing what could be on the exit of the bend.
Old 21-07-10, 05:25 PM   #7
the_lone_wolf
Captain Awesome
the_lone_wolf's Avatar
Stamp on the back brake until you have to turn then power through swinging the back around to keep you on the road
Worked best on the gravel pistes of Morocco when a corner caught us out, not much point in trying to use the front wheel even with a knobbly...
(•_•)
( •_•)>⌐■-■
(⌐■_■)
Deal with it...
Old 21-07-10, 05:31 PM   #8
Mark_h
Mark_h's Avatar
The official recommendation is to only ever be going at a speed whereby you can come to a complete stop on your side of the road in the distance you can see to be clear. Had you done that, then you'd have come to a prompt stop just before the gravel. However in the real world........
1. Should have spotted gravel dust on the other carriage way as traffic coming the other way would have driven over it and that should ring alarm bells.
2. Scrub off as much speed as you can before you get to the gravel. Then look where you want to go (not down at the gravel as if you do that, then that's where you go), think vertical thoughts and if possible relax. Chances are you'd be fine.
Minister for Sustainability
Old 21-07-10, 05:36 PM   #9
martin15s
just rely on all the brake and suspension mods.....
Old 21-07-10, 06:02 PM   #10
Bluefish
Don't worry about it, you wanted a new bike any how, and this is the perfect excuse, lol.
when do weekend riders begin to surface? svtomo Pennine Massive 11 17-01-10 11:39 PM
Road surface...coming off...insurance cb5_keith Bikes - Talk & Issues 22 31-05-09 08:29 PM
WATCH OUT - surface of road in tunnel larigos The Madlanders 2 18-03-09 05:28 PM
Crash.NET - Tough tyres needed for new surface. NewsBot News 0 19-10-07 09:00 AM
Crash.NET - Problems surface for Michelin. NewsBot News 0 23-07-07 08:00 AM
