Old 11-08-10, 07:40 AM   #1
danf1234
Default Bad Habit or problem with the bike - engine dies.
I need help with this one:
Sometimes, when I am coming up to a junction with the bike in second and clutch pulled in coasting along, the bikes rev's seem to drop and very occasionally it stalls. I really am struggling to replicate it, but just as I pulled into my drive this morning it did it again. I can't work out if it is something I am doing or something with the bike. i.e am I letting the clutch out slightly. However it does not jerk it just slowly dies with the revs dropping. It only seems to do it when I am coasting up to a junction.
Any ideas anyone?
Old 11-08-10, 08:13 AM   #2
Red Herring
Red Herring's Avatar
Default Re: Bad Habit or problem with the bike
Why are you leaving it in second? If you're going quick enough to be able to pull out of the junction if it's clear then I'd have thought you would want to keep the clutch engaged, if you're planning on stopping, or almost stopping before being able to go then why not go down to first?
I suppose it might be down to some clutch drag, does the engine still die if you knock it into neutral?
Old 11-08-10, 08:43 AM   #3
danf1234
Yes the engine still idles when knocked into neutral, what are the symptoms of clutch drag and what is the remedy?
Old 11-08-10, 08:55 AM   #4
Red Herring
When stationery and engine running in neutral pull the clutch all the way in and put bike into gear. Do the revs fall and the bike feels like it's trying to go forward? Another easy way to spot it is it's hard to find neutral with the engine running and the bike stationery.
Old 11-08-10, 09:25 AM   #5
XmisterIS
I know this is a slightly tangential answer, but I wonder why you're coasting in second? I only ever coast when I am in first and just about to come to a complete halt (so I coast for all of about half a second). At all other times, I've got the clutch at least partially engaged. The only other times when I coast are by accident when I either find false neutral (which seems rare), or the bugger pops out of second into neutral when I haven't kicked it up hard enough (not so rare!)
Old 11-08-10, 09:37 AM   #6
SV650Racer
It can be down to your idle speed being slightly too low.
Old 11-08-10, 09:49 AM   #7
Can also be down to running a bit rich, but if it runs fine in neutral then probably not this.
Old 11-08-10, 09:49 AM   #8
dyzio
dyzio's Avatar
Curvy or pointy?
As said, what's your idle set to? Might be too low.
I had my curvy doing something similar when I forgot to switch the choke off.
Old 11-08-10, 10:46 AM   #9
danf1234
It's an 2010 Pointy so as far as I know there is no idle adjustment?
Old 11-08-10, 11:32 AM   #10
you have just fitted a comfort bar kit have you not?
if so did you have the problem before the kit?
must be the new sticker you got.
ooohhh dont get into the habit of coasting.
i'll get me coat
Engine (on occasion) dies (briefly) at high revs full throttle lloyd_christmas SV Talk, Tuning & Tweaking 19 09-06-12 01:41 AM
Pressed stater button and the bike dies! adamw2k2 SV Talk, Tuning & Tweaking 10 26-09-09 02:20 PM
Child Dies In Quad Bike Accident Lissa Idle Banter 37 07-01-08 01:08 PM
Bike dies if unchoked muska4star06 SV Talk, Tuning & Tweaking 5 22-05-07 04:06 PM
Bad habit! Ward8124 SV Talk, Tuning & Tweaking 9 13-07-06 06:21 PM
