Old 25-08-10, 09:33 AM   #1
widget
Default Cam chain tensioners interchangable?
Pretty sure my k3 650 ones need changing but looking for just k3's is pain so was wondering are other models inter changable with this model?
Old 25-08-10, 09:35 AM   #2
Default Re: Cam chain tensioners interchangable?
Early ones are, later ones no.
Old 25-08-10, 09:43 AM   #3
widget
So i have to get replacement k3 ones?
Any way or taking them out and fixing them?
Old 25-08-10, 09:52 AM   #4
what's wrong with them?
Old 25-08-10, 10:03 AM   #5
widget
The normal ticking but the last week days got alot louder.
I revved it up to 5k and closed the throttle then you hear the slap/rattle of the chain so maybe its either sticking or between clicks.
The bike is at 40k miles now
Old 25-08-10, 10:07 AM   #6
You can take them out and inspect them. See where it is when you pull it out, if you take spring out first you can see if it has got to full extension.
Also other trick is to put it in gear and rock it backwards, thinking being that this will move chain slack to that side of cam sprockets and let tensioner go onto next click.
Old 25-08-10, 10:17 AM   #7
timwilky
timwilky's Avatar
Hmm, clever, Assuming tensioner is fully functional and not sticky
Not Grumpy, opinionated.
Old 25-08-10, 10:29 AM   #8
I am not sure this is effective myself, considering everything flaps about like a bugger as well as friction of valvegear naturally putting slack there anyway.
Old 25-08-10, 10:31 AM   #9
widget
Cheers any tips on getting them out and back again not done it before
Old 25-08-10, 10:35 AM   #10
They are easier to deal with than curvy one.
Take bolt off back, remove spring (careful, bit of tension), take tensioner out. See where it is, it is ratchet mechanism, should have some room left to move forward (into engine to take up slack).
Check for worn/broken teeth on plunger or ratchet pawl.
To replace, you must compress the tensioner, you need to move ratchet out of way to do this, it is obvious from looking at it but hard to explain.
Then you place it back into engine and bolt it down, and push spring in and replace bolt. Pushing spring in extends tensioner.
All IIRC, I suggest you double check a manual with regards doing the valve clearances on a K3 (it is in that section). That is disclaimer that I may be thinking of totally different bike or something.
K3 cam chain tensioners widget Stuff Wanted 0 24-08-10 04:46 PM
cam chain tensioners hkhksh Bikes - Talk & Issues 7 19-02-10 08:35 AM
Cam chain tensioners on a K3 lukemillar SV Talk, Tuning & Tweaking 5 19-09-06 11:28 AM
Cam chain tensioners northwind SV Talk, Tuning & Tweaking 16 05-01-05 06:33 PM
Cam Chain tensioners on a K3.. anyone?? valleyboy SV Talk, Tuning & Tweaking 7 26-12-04 12:55 PM
